Welp, not too many codes came up. (long w/ DTC report) :P
VAG-COM Version: Release 409.1-US
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,76
Address 01: Engine
Controller: 4B0 907 551 K
Component: 2.7l V6/5VT G 0005
Coding: 06612
Shop #: WSC 02325
1 Fault Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
Readiness: 0110 0101
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Address 08: Auto HVAC
Controller: 4B0 820 043 L
Component: A6-Klimavollautomat D64
Coding: 00160
Shop #: WSC 02325
2 Faults Found:
00756 - Left Vent Temp Sensor (G150)
30-00 - Open or Short to B+
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
Address 15: Airbags
Controller: 4B0 959 655 H
Component: Airbag Front+Seite 1002
Coding: 00106
Shop #: WSC 40232
1 Fault Found:
00654 - Seat Belt Tensioner Igniter: Driver Side (N153)
32-00 - Resistance too High
Address 16: Steering wheel
Controller: 4B0 907 487
Component: E Lenkrad Elektronik D03
Address 17: Instruments
Controller: 4B0 920 980 M
Component: C5-KOMBIINSTR. VDO D10
Coding: 02264
Shop #: WSC 00000
Address 35: Centr. Locks
Controller: 4B0 962 258 J
Component: Central Lock/Alarm D34
Coding: 15945
Shop #: WSC 00000
Address 36: Seat Mem. Drvr
Controller: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01447 - Sensor for Driver Seat: Height Adjust (G231)
36-10 - Open Circuit - Intermittent
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 02325
Address 56: Radio
Controller: 4B0 035 195 A
Component: Radio D00
Coding: 00115
Shop #: WSC 02325
End --------------------------------------------------------------------------------------------------
...I think the seat position code was from when I took the seat out. The left vent code; I prolly left a harness unplugged when I did the dash swap. I'm gonna assume the AC pressure switch is because the system isnt charged.
The belt tensioner and the MAF may require replacement. I cleared the codes and only the pretensioner one came back. I had cleared the Maf code 3 times already..I bet it will come back in time. Ill check it according to the Bentley, and then likely order a reman'd one from ECS.
More to come tomorrow, now if I can only find a local place that sells claybars..cripes!
Address 01: Engine
Coding: 06612
Shop #: WSC 02325
1 Fault Found:
P0102 - 35-00 - -
Coding: 0273004284
Shop #: BB 24334
Coding: 00160
Shop #: WSC 02325
2 Faults Found:
Address 15: Airbags
Coding: 00106
Shop #: WSC 40232
1 Fault Found:
Coding: 02264
Shop #: WSC 00000
Coding: 15945
Shop #: WSC 00000
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Coding: 00001
Shop #: WSC 02325
Address 56: Radio
Coding: 00115
Shop #: WSC 02325
It essentially mimics the software/hardware the dealerships use to diagnose, code, and modify all the logic components in the VAG vehicles (VW, Audi, Skoda, Seat, & maybe others).
You don't NEED a laptop, but the cable they supply is about 5 feet long and it needs to plug into the OBD port in the driver's footwell and the computer running the program. They have USB/serial cables...the serial can be extended with...extension cord, or you can hump the desktop out to the garage! :P
<ul><li><a href="http://www.ross-tech.com">http://www.ross-tech.com</a</li></ul>
<ul><li><a href="https://forums.audiworld.com/detail/msgs/32569.phtml">https://forums.audiworld.com/detail/msgs/32569.phtml</a</li></ul>
MCPaudiTT - DEFCON 1
06-30-2008 04:55 PM
SOLD2000-1.8TQMSport
11-08-2004 12:04 PM
