What is the 605 relay mod and how do you do it? Thanks......
This is your power steering relay - pull it out and it improves the feel ...
While you are at low speed the steering wheel is easier and when you remove the relay the steering is somewhat heavier. This mod is great over-all - not so much play in the wheel on the highway!
Drop panel under steering wheel, and pull out the 605 relay located on the right side.
Or in my case (skinny arms, you can get away with only dropping the panel half-way. Then you can reach in through the gap under the steering column...
