What are the headlight differences between the pre-face-lift A6, and the post-face-lift A6?
I think the plastic lens is interchangeable, but the lens on the latter has less vertical lines than the early lights.
Why do people not drop in the post-face-lift A6 HIDs to the pre-face-lift A6s? Is the plug the major difference?
I ask because the right hybrid headlight I have together has the wider spaced vertical lines in the headlights, and all of my other lights are the closer spaced, which I do not like. I ordered a replacement lens from a post face-lift A6 with the wider spaced vertical lines and I want to be comforted in knowing I did not waste a whopping $33.00, heh.
TIA,
TIA,
I did search, but searching for vertial lines on headlights is not easy to find, heh.
You sig is VERY full of info.
Also I know I have the lens with the wider spaced lines, and it fits perfect.
I'll make a new question asking what year is your car, and are the vertical lines on the headlights "__" far apart from another, or "__" far apart.
I want the wider spaced lens, since there is less writing on them, and they look cleaner.
Thanks,
Thanks,
bobinwa
A6 (C7 Platform) Discussion
16
09-14-2012 05:23 AM
saabSean
12-29-2004 07:54 PM
