What are the symptons of a failing power steering pump?
My 98 2.8L makes grinding noises at the front end only while turning when the car is hot or has been driven for a while. My indie thinks it might be a power steering pump or the steering rack. I've had the front control arms and tie rods replaced as well as CV boots.
So is what I have a sympton of a failing power steering pump?
Thanks in advance.
Thanks in advance.
I had this issue... I did a PS fluid flush and that fixed it..
Use the Pentosin CHF11s fluid only... Here is the procedure to do it.. little messy but easy..<ul><li><a href="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/psflush.html">http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/psflush.html</a</li></ul>
ECS Tuning-Audi
03-13-2014 10:15 AM
thrash
09-07-2005 01:52 PM
