What are the usual problems when the "check engine" light came on? Mine came on after service.
Should it be towed to the dealership (flatbed of course)?
Damn, it's much harder to convince my wife to get an A4 Avant now.
It could mean any of 10 or 12 things, none of which you can figure out on your own. If the light is on steady, the car is OK to drive for a while. If it's flashing, flatbed it!
When you call for service, they will tell you that it usually means the gas cap wasn't put on tightly enough, and they seem to be right most of the time. However, since you just had a service, it's more likely that something wasn't done or done completely.
department about how the check engine light had been 5 for 5 of 5 different issues.
-st
-st
I know it's not the gas cap cause I picked up the car last Friday morning. Drove it all day and the light came on on Sat afternoon. Haven't touched the gas cap at all.
I've had it come on for a loose secondary air pump hose (knocked off at dealer). It is now showing a "lean" mixture, but has corrected itself and now has gone off for last 3 days. I don't think a solid light is a problem for short term, blinking is another thing. The only other one I can remember was a coolent temperature sensor problem that required replacment.
All these were repaired at normal service intervals I believe, and really caused no concern due to knowing the problem (VAG-COM).
P.S. Did you get to drive in the little blizzard this morning? What fun!
Only *catalyst* damage...see my <a href="https://forums.audiworld.com/a6/msgs/102590.phtml">previous posting</a>.
