Whats wrong with my car, coil pack, bad gas, etc, Thanks!!!
8 Faults Found:
16840 - EVAP System: Very Small Leak Detected
P0456 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16690 - Cylinder 6: Misfire Detected
P0306 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16692 - Cylinder 8: Misfire Detected
P0308 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 -
car was fine cruising about 80 and suddenly starting missing or misfiring. stopped at next exit and car was vibrating and running ruff. shut it down and sat with it off for about ten minutes. still did the same thing after shut down. engine light was on the whole time. felt like it only had about 1/2 the horsepower that it normally does?????
VAG'd it and found the above codes. I reset it and the CEL is off and car is running fine, WTF??
P0300 - 35-00 - -
P0306 - 35-00 - -
P0302 - 35-00 - -
P0304 - 35-00 - -
P0308 - 35-00 - -
P0301 - 35-00 - -
P0303 - 35-00 -
check the simple things first > pull the plugs and see "what for"? mine were in good condition but had gotten fairly arced on the electrodes ..... when she finally decided not to start ..... also sounds like you could have popped a vacuum line or something ..... usually if you are lucky it is something simple .... maybe u got some moisture in the fuel ...try some fuel treatment .... to evap all the moisture .... worse case you wore the timing belt and its causing your mis fire condition ... Maybe someone else can chime in..good luck
when i changed it ..... i did the plugs at the same time ... they looked ok but were showing signs of arcing .... good luck
JCF
08-04-2019 06:26 PM
trevor51590
07-14-2009 11:06 PM
