wheel and tire fitment
I have an A6 2.8
What would be largest tire on 18" wheels that would fit on this car? Plus two size is 235/40's.However I would like to get a wider tire than that 245's 255's and also 45 or 50's.
- ride height (is the car lowered?)
- wheel width and offset
- brand of tire (some run wider than others)
If you can provide this info, you can probably get a more accurate response from the forum. However, my gut tells me that you're best bet is to stick with the 235/40R18.
Good luck,
Shaun
Good luck,
Shaun
I have not purchased the rims or tires at this point. I was looking at the RS6 knock offs which are 18" 8.5" wide with a 35 offset. The car has not been lowered.I was also thinking of Kumho's for rubber.
The width and offset of those wheels might cause a wider tire to stick out beyond the fender lips, which would look strange imo. You could also go with a taller tire, but it will affect your speedometer accuracy and raise the ride height even further than it is stock, which would again be a drawback, imo.
Basically, the answer to your question is yes, you can squeeze a slightly larger tire on those wheels on your car. I guess the question is why, and are the asthetic trade-offs worth it? That's up to you...
Shaun
Shaun
AudiWorld Expert
and the clearance is slim to none, (and slim is leaving for the weekend), so you may not have as much room as you think. Best way to really find out is to see if anyone else has used that configuration, or find a similar setup and try it out before you spend any $$$.
<ul><li><a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&tc=photo&item=79587 31199&category=66484">http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&tc=photo&item=79587 31199&category=66484</a</li></ul>
You have the rs6 knock-offs on your A6? What size rims?What tire size do you have?
All info is in their catalog, or you could call them...office is in New Jersey I think.
