When recoding my transmission, if I already have an 'S' gear....
Old 05-01-2007, 06:32 PM
JD797's Avatar
Default When recoding my transmission, if I already have an 'S' gear....
then should I just recode it to '00022', which allows me to go to redline in 1st, instead of '00032', which has that feature, along with the sport mode feature?
Old 05-01-2007, 06:36 PM
THM
THM's Avatar
Default Re: When recoding my transmission, if I already have an 'S' gear....
<ul><li><a href="https://forums.audiworld.com/a6/msgs/145099.phtml">here</a></li></ul>
Old 05-01-2007, 06:38 PM
JD797's Avatar
yea, that's what made me realize the fact, just wanted to double check,didnt wanna screw anything up
Old 05-01-2007, 06:43 PM
Member
audikillsbmw's Avatar
I should do the 00032 mod soon...sounds like fun : )
Old 05-01-2007, 07:07 PM
THM
THM's Avatar
Default Re: I should do the 00032 mod soon...sounds like fun : )
you getting vag?
Old 05-01-2007, 07:10 PM
Member
Eventually....
Old 05-01-2007, 07:13 PM
THM
THM's Avatar
Default Re: Eventually....
i just got one
just did windows and tranny
love how you you can put in 1st any time
Old 05-01-2007, 07:16 PM
Member
Lucky you.. : )
Old 05-02-2007, 04:14 AM
Fear the Miata!
Press's Avatar
i have one also....i'll bring it sunday if you're going to do the spring drive
AudiWorld Expert
Boston Driver's Avatar
Default FWIW - I have a 2002 4.2 and the 00032 code is different than normal S mode...
there is definitely a difference in shift points in D and S even with the 00032 code. The S seems to hold gears longer before shifting, and will seldom go into overdrive on the highway.
One plus (at least it works on my car) is that the tiptronic buttons on my steering wheel are able to shift even if I am in D or S. I do NOT have to shift the lever into Tiptronic mode to activate those buttons. After 8-10 seconds on no active shifting with the buttons, it reverts back to D or S.
Not positive if that works the same way on the 2002 2.7T Tiptronic as well.
Quick Reply: When recoding my transmission, if I already have an 'S' gear....
