where is the rear differential oil pan located?
there should be a plug to drain (look at the bottom of the diff) and a separate plug to check the fluid level higher up near the drive shaft. IIRC the capacity is 1.5L.
If you're going to change the diff fluid, always make sure you can remove the fill plug before you take out the drain plug - ancient Land Rover proverb.
