will after market speakers work with stock radio and sub in trunk?
assuming that this is a bose symphony system, the only replacement speakers that will be compatible
are replacement bose speakers or other 1ohm speakers which are unusual/uncommon.
yes that will most definitely work if you're running the sub & amp together and using the stock
unit to power the bose.
You may be required to upgrade the bose speakers if you wish to run a seperate amp to those locations instead of the orig. head unit. If it is a 1ohm speaker, it would put a lot of load on any std. amplifier, especially if you're running eight of them.
S4_Aviator :: WMS
15
02-05-2008 06:44 PM
Kampoenk
02-23-2002 09:11 AM
Lucy in the Sky with Diamonds
12-16-2001 04:32 PM
BTCC A4
05-25-2001 07:04 AM
