Wind noise from my doors
Hey everyone, when driving above 60 MPH now in my 2.7 I hear ALOT of wind noise from my driver side door and / or my rear driver side door. What can i do to fix this (new seals or something)? Thanks
I have had that problem but really mainly in heavy crosswinds, where they suck the top of the door away from the body a bit. The dealer says that they are aware of the problem but there is no fix. My seals are fine and the door appears to be adjusted properly based on a visual outside inspection. If you find a fix, let us know.
I've chased this a lot, replacing sunroof seal, realigning door striker plates and window subframes. No definitive cure.
I have noticed if you put the HVAC on recirc. that the noise goes down; presumably cabin doesn't pressurize as much from the outside air coming in at speed.
I haven't had the time to try the recommendations yet.<ul><li><a href="https://forums.audiworld.com/a6/msgs/481810.phtml">https://forums.audiworld.com/a6/msgs/481810.phtml</a</li></ul>
awdinut
12-30-2017 03:58 PM
Chapaarell80
Audi Original "S" Cars
03-13-2006 06:59 PM
