Wing Mirror options
Wing Mirror options
This follows up my previous post on wing mirrors.
It turns out that I have two options for a driver's side wide-angle wing mirror:
1. Convex auto-dimming non-tinted glass
2. Aspherical auto-dimming blue tinted glass
Does anyone know what the advantages/disadvantages of the two mirrors are?
aspherical mirrors give less of a blind spot
ever see those side mirrors that have a little circle mirror attached to them...thats an aspherical mirror...has more of a concave shape IIRC and lets you see more of the road and the side of your car.
Truck drivers use these all the time.
i think it depends on the lens type...
i know a lot of cameras use aspherical lenses...maybe mirrors use shpherical lenses...
either way...its the opposite of the convex mirror...
Re: aspherical mirrors give less of a blind spot
I'm not sure I'm following the back and forth here.
If I understand things, both the (spherical) convex mirror and the aspherical mirror are "wide-angle" mirrors. On the passenger side mirror, there is standardly a convex mirror. An aspherical mirror, since it does not have a constrant curvature, like a spherical mirror, can have wide and wider angles, and so would be more effective.
The aspherical mirrors are popular (regulated?) in Yurrup...
They are more-or-less plain convex over the inner 80% of the mirror, then the outer 20% (or-so) bends 'out' at a more extreme angle, giving a wider view at the edge. Some manufacturers use a mirror that has an actual break line between the two areas (making the change obvious, but distracting IMHO), others (Audi?) just change the curvature. Kinda like the difference between bifocal glasses and those newer ones without the line (forget what they're called).
NHSB Mirror Study
I found the following study on the web comparing planar, spherical and asperical driver's side mirrors, all of which are permissible by European regulations. Not too surprisingly, the study says there is a trade-off between elimination of blind spot vs. image size reduction leading to mis-judging whether there is enough space to change lanes.
My own experience is the former is a clear advantage, as one quickly adjusts one's judgement of the gap, given the size of the image in the mirror, just as one does with a spherical passanger side mirror.<ul><li><a href="http://www-nrd.nhtsa.dot.gov/PDF/nrd-12/TNOmirrorfinalrept.pdf">http://www-nrd.nhtsa.dot.gov/PDF/nrd-12/TNOmirrorfinalrept.pdf</a</li></ul>
90mtl
09-26-2007 06:13 AM
ArtsA6Q
16
05-21-2007 11:13 AM
SmokeyA4turbod@ebay
08-11-2001 07:25 AM
