Writeup on front rotor & pad replacement(HP2)
Following up on my other thread I've purchased OEM rotors and Akebono pads. I'm going to tackle the job myself and have a full shop and tools at my disposal. I've having a difficult time locating a full writeup, or even better video on the removal of the rotors. I've searched far and wide but have only found bits and pieces. Does anyone have a link or some pointers to help me out? Thanks.
Just remove the two big effing bolts that hold the HP2 calipers to the caliper bracket. They're in there with about 150 ft-lbs if not some locking compound. When you put them back in use loctite blue. Red on such big bolts just leads to problems.
echoing SJB's comments on caliper bolts. Also, getting the first bolt back in can be a struggle, if the threads don't catch right away.
I have found that if you remove only the lower bolt and just loosen the top bolt, you can pivot the caliper back and wiggle the rotor out, if you hold your mouth right.
This saves having to suspend the caliper with a bungie and makes the re-install much easier. Once the new rotor is in place, just swing the caliper down and replace the lower bolt, and tighten both.
It's often amazing the crud that collects in the caliper cylinders over 10-15 years, even with annual or biennial fluid flushes and flushes with pad changes.
Don't limit yourself to S6s. Search for HP-2. I've seen several - i cannot recall exactly where. Some are here.
Removing calipers - the main problem is that the bolts are very tight, and are accessed from the REAR of the caliper (much easier from below). Of course you also need to look carefully at how the sensors come apart (push in a tab and turn to remove from carrier).
Rotors have no set screw in them.
Calipers should be cleaned and lubricated ideally. The guide pins are VERY tight and if you are nto careful you can damage the star heads (torx?).
NJOY
Grant
NJOY
Grant
NJOY
Grant
NJOY
Grant
John P. (TT 225)
16
12-11-2006 09:02 PM
axecheerful
29
04-22-2004 07:18 AM
S4Patrick
03-11-2004 04:22 AM
