Xenon problem again..
I have posted on this problem before but never really got the answers I was looking for. He is my problem, my Xenon on the driver's side does the proper movement when switched on (moves up, down slightly and remains) but after about a minute or two it drops all the way down and shines on the ground right in front of the car, pretty much useless for driving above 20 mph at night.
My business partners car (identical to mine) is still under warranty and is set to go back to AFS in the next month or so. If I remove the housing on his and replace it with mine, will that solve the problem? Meaning is the fault in the housing or is there some module that is telling the housing and its internal components to lower the beam. I have no problem scamming this repair with Audi as mine has been repaired 3 times and is now out of warranty.
My other thought is that I have read that you can adjust the parameters of the up and down movement with a VAG-COM, would it be possible to adjust my lower parameter almost all the way up thefore when it drops down it is still at an exceptable level. Is this all wishfull thinking and I am just screwed and need to pony up for the repair?
with how many times it has been in for the same thing. I hate to pay $500 or more and have it happen again in 1 year. So you think all the controls are contained in the housing?
just one used for both, so the passenger side should drop as well. Not sure on manually aiming them and what to unplug actually, any thoughts?
The fix was a total replacement of both the headlights. I don't think a manual adjustment will do any good, because if is like mine, it will rise up some times, which would blind oncoming traffic. Mine seems to be more prevalent in cold wet weather, but it has been worse over the past month in hot weather.
for free....
Am I right?
This is what I've been told when dealer didn't find anything wrong with my car (OK frosen on gauge panel)....
Did you call audi?
Am I right?
Did you call audi?
Seems to me that this auto leveling thing is more trouble than it is worth. Mine are not auto leveling and have never been a problem. Don't really see why you need this feature unless you drive with a heavy load in the back. Even then, do as I did, adjust the high beams and the low separately. Unless you have bi xenon that is.
