Yay! Billowing blue smoke
So I get on the road this morning, it's about 12 degrees out and my A6 2.7t is puffing out blue smoke like a chimney.
Initially I suspect head gasket, but this is my first turbo vehicle. -Is it possible that a turbo failure would have a similar symptom?
It appears that the oil burn came on somewhat gradually (over a week or 2). I noticed a burning oil scent, but guessed it was a cam seal or something like that. Now obviously it's a bit more severe than I'd guessed...
Any thoughts on items to check or potential failure points would be greatly appreciated.
Thanks!
Thanks!
week while I was doing the suspension. I test drove it and when I got back there was smoke pouring out from under my hood. I assumed the worse but it was only oil on the manifold.
When the cam seal goes bad the oil drips onto the manifold.
Is the smoke coming from your tail pipe or engine bay?
<a href="http://s64.photobucket.com/albums/h195/Fast_N_Snow/?action=view¤t=oil.jpg" target="_blank"><img src="http://i64.photobucket.com/albums/h195/Fast_N_Snow/oil.jpg" border="0" alt="Photobucket"></a>
You can see where the oil collected on the manifold. As soon as that heats up it stinks and sometimes smokes.
..which means you'll foul the cat. Not a good sign.
I would get at least moderately excited. Yes, blue smoke is one sign of turbo failure.
However, another likely cause is valve stem seals, whcih is considerably less serious.
G
G
Follow this thread for description of symptoms and suggestion on how to deal with it until you can properly diagnose/fix it.<ul><li><a href="https://forums.audiworld.com/a6/msgs/822079.phtml">Smokescreen 'b Bone - Klick here!</a></li></ul>
Thank you very much!
Due to my 20vt project, I have no space in my garage to work on the A6. I was dreading needing to do a head gasket in the driveway!
You all made my day
You all made my day
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
