009220 - EVAP Leak Detection Pump Sense Circuit: Implausible Signal
I am getting the following error on my 2005 A6 3.2
Any idea what it can be ? I was guessing it has something to do with the gas cap may be.
VCDS Version: Release 908.2
Address 01: Engine Labels: 06E-910-559-BKH.lbl
Control Module Part Number: 4F2 910 559 B HW: 4F1 907 559 A
Component and/or Version: 3.2l V6 FSI 0030
Software Coding: 0000000000000000
Work Shop Code: WSC 22811 444 89524
1 Fault Found:
P2404 - 006 - Short to Plus - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 219
Reset counter: 40
Mileage: 84361 km
Time Indication: 0
Date: 2009.09.10
Time: 07:15:48
Freeze Frame:
RPM: 1184 /min
Mass Air / Rev.: 98.1 mg/str
Temperature: 34.5°C
Idle
Voltage: 13.97 V
Speed: 48.0 km/h
Readiness: 0000 0000
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 40
Mileage: 84361 km
Time Indication: 0
Date: 2009.09.10
Time: 07:15:48
Freeze Frame:
RPM: 1184 /min
Temperature: 34.5°C
Idle
Voltage: 13.97 V
Speed: 48.0 km/h
Finally I have the problem solved.
The issue was a tube was squeezed due radiator heat.
The dealer at livermore,ca changed the PCM (aleast not on my money). What a bunch of morons? Finally one of the technician at the same service center did the trick.
Hi can you tell me where this is located? My 2005 A6 seem to be having the same problem. The MIL light went away during the winter and now is back.
Very intuitive. Who would have thought?
Things are pretty crowded and hidden in that area, just thought it might be easier if I had an exact location, at least which side or maybe a picture of it on the car for reference.
I am the proud new owner of an '05 A6 3.2Q, and she is throwing same code, P2404. I appreciate the help! Plan on removing bumper to assist in getting into these tight spots. She is also throwing codes P2006, and P2007. any assistance on these?
