04 a6 question
I have an 04 a6 and the water pump went out on me and the shop is trying to tell me that the "worn" out timing belt caused this to happen.
so is this true or not?
Source: Gates Tech Zone
https://www.gatestechzone.com/en/pro...-failure-signs
So can i get away with just changing out the water pump for now and do the belts when i get the money? I dont have $1000 to do both the timing belts and water pump.
also this is the quattro v6 twin turbo if that makes a difference
I'm sure it's possible to just change the water pump out but I honestly don't have enough knowledge about that engine to know if it was indeed the belt that caused it. It's possible and could be likely however I can't recommend anything. Ill try to do some research and get back to you but at this point I would have to recommend changing both just to be safe. Perhaps talking to someone who knows more about this sort of stuff would be a good idea.
2. This is wrong forum.
anb957
02-05-2009 08:21 AM
Orlando 4000S
10
03-17-2007 04:37 PM
Rosati (Ginzo)
09-05-2006 11:47 AM
Avants
03-24-2005 08:32 AM
