05 A6 3.2 leaky injector on cylinder one...
#21
I have same car year and motor a6 2005 BNK and I have the misfire issue I've read through your threads about this and I'm going to try out/inspect test issues tomorrow. I think one thing you have not tried is the battery adaptation and or replace the charge controller black box on neg terminal in trunk. These cars need to have a vag com battery adaptation done whenever you change the battery, if you don't bad misfire issues. also I think the charge controller on our cars had a recall.... worth looking into I'll let you know if I sort mine out and I'll let you know what I discover tomorrow. cheers
#22
#23
no, nothing important. Some crap about infotainment, door handle, stuff like that, but nothing out of ordinary. no engine codes or similar.
never had, when I had some codes that was all down to valve solenoids and fuel pumps. After that was replaced, not a single CEL or code regarding engine.
If so, what you want to do is get the engine good and hot, shut it down and under advanced measuring values track the pressure off of the HPFP. Over the course of say 10 minutes it should rise to about double its initial value from the heat soak and then begin to decline. Any other pattern is a sign of a leak at the pump(?) or in the upper injector seals.
I hope this helps.
#24
1) Is there a difference in the brown and blue o-rings. Blue ones appeared to be approx. 1/64" shorter than the brown. But the brown ones could have just been a little swollen from usage or heat.
17
06-24-2013 04:47 AM
