'05 Audi A6 3.2 P1158 and P0068 codes
I ran VCDS on my '05 Audi A6 3.2 Quattro due to a CEL and got error codes P1158 and P0068 as shown below:
Sunday,15,May,2016,10:33:28:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 67 72 76 77
VIN: WAUDG74F85N098366 Mileage: 141490km/87917miles
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0020
Revision: --H15--- Serial number:
Coding: 0000000000000000
Shop #: WSC 25015 444 90125
VCID: 2B5F19758A1E111
2 Faults Found:
004440 - Manifold Pressure Sensor (G71)
P1158 - 007 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 62
Reset counter: 38
Mileage: 138652 km
Time Indication: 0
Date: 2016.01.10
Time: 07:16:13
Freeze Frame:
RPM: 1312 /min
Mass Air / Rev.: 98.1 mg/str
Temperature: 87.0°C
Idle
Voltage: 13.67 V
Speed: 39.0 km/h
000104 - MAP/MAF Throttle Position Correlation
P0068 - 007 - - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 62
Reset counter: 40
Mileage: 138652 km
Time Indication: 0
Date: 2016.01.10
Time: 07:16:13
Freeze Frame:
RPM: 1280 /min
Temperature: 87.0°C
Idle
Voltage: 13.67 V
Bin. Bits: 00000010
Readiness: 0000 0000
I replaced the MAP sensor a while back due to the same error, but it didn't change anything. What should I be looking for?
Chassis Type: 4F0
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 62
Reset counter: 38
Mileage: 138652 km
Time Indication: 0
Date: 2016.01.10
Time: 07:16:13
Freeze Frame:
RPM: 1312 /min
Temperature: 87.0°C
Idle
Voltage: 13.67 V
Speed: 39.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 62
Reset counter: 40
Mileage: 138652 km
Time Indication: 0
Date: 2016.01.10
Time: 07:16:13
Freeze Frame:
RPM: 1280 /min
Temperature: 87.0°C
Idle
Voltage: 13.67 V
Bin. Bits: 00000010
Chassis Type: 4F0
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 62
Reset counter: 38
Mileage: 138652 km
Time Indication: 0
Date: 2016.01.10
Time: 07:16:13
Freeze Frame:
RPM: 1312 /min
Temperature: 87.0°C
Idle
Voltage: 13.67 V
Speed: 39.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 62
Reset counter: 40
Mileage: 138652 km
Time Indication: 0
Date: 2016.01.10
Time: 07:16:13
Freeze Frame:
RPM: 1280 /min
Temperature: 87.0°C
Idle
Voltage: 13.67 V
Bin. Bits: 00000010
Chassis Type: 4F0
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 62
Reset counter: 38
Mileage: 138652 km
Time Indication: 0
Date: 2016.01.10
Time: 07:16:13
Freeze Frame:
RPM: 1312 /min
Temperature: 87.0°C
Idle
Voltage: 13.67 V
Speed: 39.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 62
Reset counter: 40
Mileage: 138652 km
Time Indication: 0
Date: 2016.01.10
Time: 07:16:13
Freeze Frame:
RPM: 1280 /min
Temperature: 87.0°C
Idle
Voltage: 13.67 V
Bin. Bits: 00000010
David Cormier
New Member Welcome Area
01-18-2018 05:30 PM
Tonytza
VAG-COM Discussion
04-14-2008 07:14 AM
