06 NAV system
Starting to figure out my new to me 06 A6 3.2q. How do I get/install the navigation since that wasn't installed as an option when the car was new. Was that offered as a pay/term service or do I order the dvd's from the dealership? Any aftermarket alternatives that use the OE screen?
Thanks,
Rob.
06 A6
01 A4
Thanks,
Rob.
06 A6
01 A4
Hi Rob-
It's not that bad to install, especially if you don't tie into the shark fin.
About $1,700 all in.
4E0910888FX Nav unit
4F0051322 Retrofit kit - includes all cables and antenna that goes under package shelf
Available from AudiUSAParts, ECS and others.
![](http://c1552172.r72.cf0.rackcdn.com/143703_x600.jpg)
You can get the DVD from the dealer or from NAVTEQ.
None that I know of.
If you had a carputer or something with video out you could use a MOST attached video device.
That would require an FBAS enabled module though - e.g. backup camera already installed.
Hope that helps. -Jake
Absolutely 200% top notch and their prices beat just about everybody.
They are an Audi dealer in Oregon, all OEM.
Loree and Jake over there are always great.
I buy from them pretty regularly for the A8 and just ordered a tail light insert for the A6.
Good to know where to buy my Audi products! Thanks!
I did a DIY on the NAv system - its not that hard, took the two of us a full day since it was the first time.
Bought the kit from ebay - about $1400 and came with instructions. The DVD player and wires are all that is required. Kufatec has the wires for 99 euros I believe.. and you can look around for the DVD on ebay etc.
Thanks for the input. I don't have a problem with a portable unit. That's what I have in my A4. Just wanted to learn about what it would take to have the factory nav working.
Thanks,
Rob.
06 A6
01 A4
Thanks,
Rob.
06 A6
01 A4
http://www.kufatec.de/shop/product_i...---MMI-2G.html
Its very easy to install, I did this by myself in less than 2 hours, including removing and installing all trim pieces. As far as I know, all C6 A6 models in the US have the GPS antenna built in and can be accessed via rear A pillar.
The only thing you have to be careful about is when working with the fiber optic cables, as the slightest bend would render them unusable.
I didn't have the $2000 option from factory, but for $550 I got everything, DVD Unit, cables, and 09 OEM DVD Maps.
