07 A6 4.2 P0016
My 07 A6 currently has a P0016 code Bank 1: Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incorrect Correlation. I know there are many posts on this, but is it fair to say the solution seems to be all over the map?
The car is at the shop now and below are the codes. I'm trying not to panic. Although a timing issue, I'm assuming it isn't a broken guide or tensioner because I haven't been hearing any rattling or odd noises at start up.
With the rough idle there are misfires on 1, 5 , 4. Are the locations of these misfires important to my code? These are actually the first 3 cylinders in order that the car fires the engine. Does this mean anything? Does it mean anything the cylinders are on opposite sides?
Here are the codes.
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 001 - Incorrect Correlation - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:50:39
Freeze Frame:
RPM: 721 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 13.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000769 - Cylinder 1
P0301 - 008 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000773 - Cylinder 5
P0305 - 008 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
2007 A6 4.2
Here are the codes.
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:50:39
Freeze Frame:
RPM: 721 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 13.0°C
Voltage: 13.843 V
P0300 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000773 - Cylinder 5
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
2007 A6 4.2
Here are the codes.
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:50:39
Freeze Frame:
RPM: 721 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 13.0°C
Voltage: 13.843 V
P0300 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000773 - Cylinder 5
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
2007 A6 4.2
Here are the codes.
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:50:39
Freeze Frame:
RPM: 721 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 13.0°C
Voltage: 13.843 V
P0300 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000773 - Cylinder 5
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
2007 A6 4.2
![](https://cimg5.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/6af1ad38_5e2c_43b2_878f_aeed9ed770fa_428fefd5cdbe6cd6290b79136e5ecedd7fe5f5d5.jpeg)
gateway
12-02-2012 11:09 AM
