09 A6 headlight convertion
Hey, Guys, I am about to order my first pair of 09 headlight.
Just wanna ask if any of you did it before i want to confirm the part number, below is the number audi canada gave me.
4F0 941 029 DK/4F0 941 030 DK.
i couldnt confirm on guinuineaudiparts since they dont have 09+ parts loaded in their online database. do a quick search for 09 headlights, i do recall a post with part numbers posted recently (last couple months)
I did but couldnt confirm it cuz i found cp and cj at the end but the audi canada told me that they only have dk for the lamp. and i also is the existing ballast would work on the new lamp? really need some help for that if i could confirm that I could bring them here for a very sweet price.
You will require a new ballast to do the conversion
https://www.audiworld.com/forums/sho....php?t=2750403
Hello,
I have the same project than you : to install the new A6 Leds headlight on my 2005 A6 C6, equipped with the Bi-xenon and Adaptative light.
Here are the references of my new headlights (without Adaptative Light) that I have just bought:
Right headlight : 4F0 941 004 CP,
Left headlight : 4F0 941 003 CP.
Price for both : 250 euros.
I have also bought two new ballasts (150 euros for both), and two new D3S xenon bulbs (80 euros for both).
I hope to install them next Friday.
I think that the Adaptative Light mechanism of the previous headlight could be installed in the headlights.
Gasy
Gasy
Hello,
Gasy
Gasy
Pls up let me know more, if possible post some pics?
Hello,
Gasy
Gasy
-2 headlight housings from RS6 with or without adaptive light (AFS) . I have AFS so for me they were numbered like this :
left side - 4F0 941 029 CM
right side - 4F0 941 030 CM
- a power module with software for onboard electrical sistem (bordnetz steurgerat) with the latest version - 4F0 910 279 K
You need to do some modifications to pins that are going into bordnetz via T10 and T32 couples. These are the install procedures (copyright of MotorTalk):
Left:
- At the gray connector T32c line black / red pin 4 separate
- On the black connector T10a line gray / white pin 6 separate
- Line from pin 6 connector T10a gray / white with black line / red line set from associate
- The pin T32c / 4 black / red is no longer needed
- On cable connector T10a white / black pin 8 separate
- Head of connector T10a Pin 8 white / black line with gray / white line sentence combining (PWM signal)
- The white line / black line in the record is no longer needed
Right:
- At the gray connector T32c line black / red Pin 15 separate
- On the black connector T10a red line / yellow Pin 1 separate
- Head of T10a pin connector 1 red / yellow line with black / red line set from associate
- The pin T32c/15 black / red is no longer needed
- On cable connector T10a green / blue pin 2 separate
- Head of T10a plug pin 2 green / blue with red line / yellow line sentence combining (PWM signal)
-- The green line / blue line in the record is no longer needed
After all that is done you need to do some coding with VCDS :
Module 09
Now only the fourth place in the wiring to "5" (S6/RS6) encode (xx5xxx) and should do just fine.
Here is typically what I have bought:
http://cgi.ebay.de/2-x-Audi-VW-D3S-G...3A1%7C294%3A50
or
http://cgi.ebay.de/Philips-D3S-Xenon...3A1%7C294%3A50
I can tell more on next Friday, after my installation.
Gasy
All my parts are OEM parts!!
or
Gasy
or
Gasy
