Last edit by: IB Advertising
- Audi A6 C6 How to Replace Upper Timing Chain Tensioners<br>Step by step instructions for do-it-yourself repairs.
2005 A6 3.2 FSI Timing Chain Tensioner
#11
Yes, I replaced the passengers side upper tensioner and the noise was gone. Each of the upper upper tensioners has a hydraulic piston that tensions the chain. I decide to replace the drivers side for good measure and am almost done. I have to say the hydraulic piston in the tensioner appears to be the achilles heel of the assembly as everything else looks in good order. I've seen alot of posts saying the the only sensible course is a complete engine pull and replacement of all timing chains, tensioners, etc. I say it's complete Bull$#%t.
#13
I just found this TSB indicating the sound is normal for 1-2 seconds upon startup. What do you make of it?
http://uberlame.com/a6_tsb/Engine/Ra...ne%20start.pdf
#14
#15
I have read that the only tensioner that you can change with the motor in the car is the upper L & R on the 3.2. The motor has to come out to do anything on the 4.2. You will need to buy or rent a locking tool to keep everything in place while swap out the tensioner. Good Luck.
#16
Hey, I think I have the same issue on my 2008 with 80k miles. Loud rattling that lasts around a second or two upon startup.
I did a lot of work on my '98 A6, including timing belt but have done nothing major on this one. I have VAGCOM and the audi online service manual but would still love to see how it went for you.
#17
There is a small lower tensioner, and if that fails then you are out of luck, the engine has to come out. As I said initially, im prepared to do it if needed but it was not. I bought the entire engine timing tool set for $150 new off of ebay, as well as crank turning tool ($20) and 12point 14mm camshaft socket ($9).
#18
https://www.audiworld.com/forums/sho....php?t=2809217
#19
Nice, good luck with this. Most likely it is the upper ones as they are the more common. Here is my post on this when I did not know what the heck was going on.
#20
Great job, nice to hear it all went well. Now that u mentioned S.Belt and tensioner, I have the parts and still have not done it at 144k. Maybe I will get on it this weekend.
