2005 A6 4.2 Intermittent Vibrations from the rer
Hey there, Just wondering if anyone could place a finger on what's causing this weird vibrations i've been experiencing.
Frequency: Intermittent-but occurs only in 6th gear and past 60MPH
Sound: sounds like when you go over the strips on the highway when you get too close to the side.
Location: Seems to be coming from the rear axles of the car
Looked over the car and didn't seem like anything was loose. I'm in Champaign IL and the nearest audi dealership is an hour away, i was hoping to maybe get an idea of what it might be before heading over and finding out they don't have the part.
Thanks!
Cheers,
Tim
P.s im hoping it isn't the quattro acting up.
Thanks!
Cheers,
Tim
Sounds like nearly the exact symptoms I'm having. I suspect my torque converter is going bad, and what started as only being in 6th gear is now happening in lower gears.
No codes set, but I'm going on a road trip this evening, and will be logging the data via VCDS.
I think the feeling that it is coming from the rear of the car is really just where the driveline is transmitting the shudder.
Thanks!
Cheers,
Tim
Thanks!
Cheers,
Tim
I live in Bloomington, IL I assume you are taking your car to Suds. If you car is not under any type of Warranty I recomend taking it to an indy shop in Peoria called Kauth & Mayeur. Good people and they know Audi
Screw me.... They said that the transmission fluid smells funny. So it's a transmission problem. They want to do a transmission flush but if that doesn't work it's $8k+ to change the transmission.
Anybody know if a transmission flush would solve a vibration problem or are they trying to get me to flush $800 down the bowl just for kicks?
How many miles on your car?
Thanks!
Cheers,
Tim
Thanks!
Cheers,
Tim
i have the exact same thing going on with my 4.2
Thanks!
Cheers,
Tim
Thanks!
Cheers,
Tim
Have you looked at this TSB in the library linked in my signature?
http://uberlame.com/a6_tsb/Transmiss...ear%20axle.pdf
