2005 Audi A6 3.2 brake problem
Hay guys I'm new to this I have a 05 Audi A6 3.2 Quatro I just changed the rear brakes and alot of air got into the lines, so I'm having a problem bleeding them I used a one person bleeder and also the brake method. Still my brakes are still soft, with more looking into it I found that my platic electronic box behind the rear brake caliber is cracked could that be what causing air to remain trapped inside it doesn't seem like it get any brake fluid in it but I'm sure you could help with that please and thank you for any help I don't wanna buy the platic back if I don't need to I just enlisted in the airforce and go laid of work. So money is tight at least until I get sent to basic training
Thanks for the help guy still no luck ima go leave my daughter at my in laws house then try again with the bleeding so that platic back of the caliber shouldn't be letting air in right?
That plastic box is most likely a cover for a connector to the electric motor that operates the parking brake.
When pads are changed on the rear of a car with EPB the adjuster must be electrically withdrawn (well, there is a way to do it mechanically but you have to take stuff apart) before the new pads are inserted. VCDS is one way to reverse the pad adjusters.
If you forced the pads out with some sort of mechanical spreader you probably effed up the system.
ECS Tuning-Audi
Audi A3 / S3 / RS 3 MKII
09-17-2015 12:23 PM
Audi A6 PB racing 8pot front brake kit.
JdmA6guy
09-17-2015 03:59 AM
ECS Tuning-Audi
09-02-2015 11:39 AM
