2005 audi a6 front brakes and rotors
You will need a metric 6pt socket and breaker bar or your favorite impact driver to take the calliper carrier.
you will need torx socket to take a small bolt on the caliper.
and then you might need all sort of tools to get the rotor off. It depends how frozen it is. search youtube for all sorts of ideas how to take frozen rotor off the hub.
This been said, the know how is not in what tools to use but how to do it. If you not sure what tools to use, you might now be sure how to do it and brakes is not the place to learn on own mistakes. i.e. you can kink the brake hoses and then they will burst.
The link I shared was for a 3.2 BTW...how are your brakes different?
With the exception of EPB and the stupid inside out front brakes on the 200s in the 90's, Audi pad and rotor changes have not changed much.
I just did the rear brakes on my wife's C6.5 Avant. To make sure I had not forgotten anything in my old age, I looked at some Youtube's to refresh my memory. BOY THERE IS A LOT OF BAD ADVICE OUT THERE. Idiots unnecessary taking off the caliper bracket. Idiots hot-wiring the EPB. Idiots failing to mention to check, clean and grease the guide pins.
Be well!
aebarto11
12-28-2017 06:56 AM
krishnachaithanya82
13
12-14-2017 12:59 PM
Audi Other 2005 S4 Avant For Sale w/WARRANTY
romanr3
03-16-2017 11:29 AM
Audi A6 Audi HP2 Calipers & Rotors
autlaw
03-14-2017 07:11 PM
