A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Old 09-06-2016, 10:55 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C6) Brake Guides
Print Wikipost
2006 A6 Avant Center Brake Light
Old 08-09-2011, 10:16 AM
2.7allroader's Avatar
Default 2006 A6 Avant Center Brake Light
Anyone have the part number and removal instructions for the high mounted rear stop lights?
Old 08-09-2011, 10:31 AM
Banned
Jake-AudiUSAParts's Avatar
4F9-945-097 $52.50 IN STOCK! I don't have any experience changing them out but I am sure someone here (audiworld) has good instructions.
Old 08-09-2011, 10:54 AM
Thank you very much for your help.
Old 08-09-2011, 11:28 AM
am_ver's Avatar
From what I remember, it was accessible when I was installing my Nav.. the c-pillar trim needs to come off. This was some time ago, so I could be wrong.
Old 08-23-2011, 04:46 PM
On the Avant, you'll need to remove the trim from inside the lift gate. Once all that is removed, you can now see the High-mounted stop light assembly from inside the lift gate. The black plastic(retainer) is what holds the assembly, and you'll need to slide the plastic towards the left This will disengage the retainer from the unit. You'll need to jiggle the unit loose as the clips need to come off the unit before it can be pulled out.
Reassembly requires the clips and retainer to be reinstalled while the unit is outside. The unit just pops in after.
Old 08-25-2011, 06:28 AM
j_sonel's Avatar
Mine loses connection regularly and I have to clean out the plug and reinstall... which works for about 2 weeks, then I need to do it again. I'm a pro at removing that thing now. I may just solder the connection solid if it keeps acting up.
Old 08-28-2011, 07:08 PM
Try using Dielectric grease.
Old 08-29-2011, 06:49 AM
j_sonel's Avatar
I've used it twice... lasts a few weeks then randomly starts losing connection again.
Old 08-30-2011, 06:41 PM
I replaced my stop light assembly two weeks ago, and knock on wood, I haven't gotten the error code.
Old 08-31-2011, 12:50 PM
j_sonel's Avatar
Did it come with new clips and the plastic sliding portion?
Quick Reply: 2006 A6 Avant Center Brake Light
