2006 A6 Avant Windshielf Washer Leaking
#11
I put the car on ramps and didn't even have to turn the wheel. I got the below parts from pelicanparts.com. I think I still have the grommet.
443-955-465-M21 $0.75 1 $0.75
Windshield Washer Pump Grommet, Brand: Contitech - Brand: Contitech
1K5-955-651-M36 $12.75 1 $12.75
Windshield Washer Pump Brand: Febi Bilstein, Brand: Febi Bilstein
#12
Great, so you just swapped the parts and all was good? I don't currently have ramps. Do you think that is necessary if I just turn the wheel? Thanks, and I guess I'll just order these parts to see if it does the trick.
#13
It is tight down there. You do need to get behind the wheel to remove the nut holding the liner (there are two). My car is lowered, so there is even less room - you can give it a try and see if you can get those nuts. Once those are removed, you should be fine and not need ramps. You might feel that there is not enough room to replace the pump, but trust me, it is possible and not very hard.
#14
I tried to replace this today and did replace the cheap washer fluid pump and put in the new grommet. It looks like the real problem is that the line connecting to the right angle connector separated at the end.
I wondered if you have any ideas. The first picture shows the right angle connector on the left. This connects to the pump on the right. What's on the top of that image is a bit of the washer hose that split and I cut off. The bottom picture shows the line, which is too tight to fit in order to push the line in. Does anyone know how to do this? Does it have to be heated or something?
#15
I took off the Front Driver side tire and the Wheel well cover to expose the washer fluid reservoir... To Test I filled some washer fluid from the top and noticed that the reservoir was full and then it was overflowing fluid back out of the hole where the fill pipe is located.. There is no O ring or any tight join between the fill pipe coming from the top and the reservoir opening..
How is this supposed to seal as when the washer fluid is full in the reservoir and you fill more from the top (Not knowing it is full) only to see it all drip out of the fill hole in the reservoir where the top pipe attaches...
Thanks much
Thanks much
At least I know when the tank is full
#17
andiamo
10
01-08-2008 09:33 AM
MachineMan
Audi allroad
06-18-2005 06:01 PM
audi6avant
01-12-2005 01:07 PM
