Last edit by: IB Advertising
- Audi A6 C6 How to Clean Cowl Drain<br>Step by step instructions for do-it-yourself repairs.
2006 A6 C6 4.2 - Found water in the driver side rear footwell, unique problem
I've scoured the internet and countless images and forums and noone seems to have had this same problem.
The Problem -
Found a bucket or water sloshing around in the rear footwell on driver side (US), after the car had been parked on a ramp during heavy rain
Troubleshooting -
1. Took it to the dealership who had repaired a bent AC drain - they said everything looks fine, no leaks from what they worked on. incompetent, conniving thieves, but whatever..
2. Removed the battery, Driver Seat and carpet on the driver side, turns out there was a water puddle along the whole floor, upto the box that holds the bluetooth module.
3. Removed the wipers, cleared all drains under the hood, vacuumed out all existing water using a shop vac.
4. Checked Sunroof drains, all clear, water poured out from where it was supposed to.
5. Jacked the car up from the front so it sat like it did during the rain.
6. Leaving everything disassembled and disconnected, hung a water hose on the windshield to simulate heavy rain and left it running, watching the interior to spot the leak.
7. 5 minutes later, water shows up in the rear footwell again! Surprisingly, it was not flowing in from the front of the car but from underneath!
So I got under the car while water was pouring everywhere, removed the plastic underbody cover with the billion screws, and saw this hole clogged -
After poking it, a steady stream came out.
Then, from inside the car I spotted the seal -
rear footwell darin hole
rear footwell drain hole seal
1. Clearly this seal was loose, removing it caused a lot more water to flow upward into the car with debris, which eventually drained from the underbody hole.
2. Plugging this hole resulted in water flowing back up into the car.
I was able to stick a finger in the hollow metal housing between the underbody drain and this drain plug.
Does anyone know how water got in this space and what this hollow chamber is???
I want to replace the seal and put everything back together but can't figure out what drain brings water into this area?
HELP!!
The Problem -
Troubleshooting -
![](https://cimg8.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/img_20160422_161845_d2f0b779ed4a88a06c4df4309703a731001abdd4.jpg)
![](https://cimg9.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/img_20160422_161911_b2ce1392f144ffce97d1609cfae222b8e3f25b6f.jpg)
![](https://cimg9.ibsrv.net/gimg/www.audiworld.com-vbulletin/1500x2000/img_20160422_161516_1fd2f9045e49e084a2eac442800d30b1b327dfd4.jpg)
![](https://cimg0.ibsrv.net/gimg/www.audiworld.com-vbulletin/1500x2000/img_20160422_161526_0db7b1e63c62e5cd4bece38582de382d4826b9d7.jpg)
HELP!!
There's a lot of threads on water ingress to our cars and these can be found here:
https://www.audiworld.com/forums/a6-...-many-2885321/
https://www.audiworld.com/forums/a6-.../#post24311818
The hollow chamber is the unibody construction. Look at the underside of your hood, its kind of the same. It'll give you an a-hah moment.
I have/had the exact same water problem that you do. Its mind baffling how water and debris can get from the cowl, into the floor unibody, eventually clogging the bung drains and then back up into the car.
I cleaned the drains out in my cowl and it kept leaking. I still haven't figured it out. Just haven't driven the car on a rainy day since I discovered the water this past winter. Now that its warmer out I need to put water into specific spots in the cowl and see if I can figure out how and where the water is getting in. I've also been thinking of pouring soap bubble water into the cowl, then hook up a vacuum cleaner in reverse to one of the floor bungs and hopefully find some bubbles foaming up in the cowl. I have a feeling its around the steering. I read a post that someone said there was a seal under it.
As for the cowl drains, the passenger side is easy to get clean, move the alarm horn and its accessible. You'll find the driver side drain under the heater box hoses. I bought an inexpensive USB camera to figure it out. I also found it easiest to do it in the dark because you can see the LED lights on the camera from above. Once you have the location of the bung with a camera you can fish it from above. I used a long plastic tie wrap to get into it.
Good luck with it.
Good luck with it.
Is your AC on? where do you live, is it humid? do you have AC water dripping below, if not i say check your Water drain for your AC , if its clog with debri, usually you can stick a hanger in there and clear it or air blast with an air gun. 70% of water leak in footwell area is due to that , and will work its way to the rear footwell.
Next have you had your windshield replace recently? possible cause bad seal job. Another way is to close all doors, and you lay upside down under the dash, and have a buddy use a water hose to water your car all over till you see it coming in.
The passenger side cowl drain is clear. I believe the drivers side one to be clear although it is near impossible to see it. Certainly no lake is forming in the cowl.
The problem was actually the unibody seals, replaced them and no more water in the car!
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Thank you guys for the quick help!
I replaced the seals and have been testing for the last few days, no more water coming in, all fixed!
New problem now - I put a new Bluetooth Module in (old one was damaged during the last flood in the car), coded it correctly, but the Mic doesn't work.
Pressing the Voice Command button shows "Button inactive".
This was working with the old bluetooth module..
Any ideas?
Any ideas?
Any ideas?
Any ideas?
Here is the full scan -
VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
Data version: 20160216
Ross-Tech: Home
Thursday,28,April,2016,17:06:11:61992
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 67 72 75 76 77
Mileage: 165980km-103135miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Sporadic communication error 1000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Cannot be reached 1100
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 560 E HW: 4F0 907 559
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number:
Coding: 0007772
Shop #: WSC 02325 785 00200
VCID: 2447A238E729D71E3A-8070
3 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:12
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 76.0°C
Absolute Pres.: 970.0 mbar
Voltage: 12.573 V
19510 - Starter Will Not Turn
P3054 - 001 - Jammed or Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:15
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: 26.0°C
Voltage: 11.303 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 Q HW: 09L 927 156 A
Component: AG6 09L 4,2 MPI USA 0040
Revision: --H01--- Serial number: 4081600
Coding: 0000002
Shop #: WSC 02327 785 00200
VCID: 326B5460ADDD49AEB8-8066
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H04 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0021352
VCID: 2D51471CB4E31656E5-8078
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 19
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 12:34:39
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x019E
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0180
Revision: 30070501 Serial number: 10600600244270
Coding: 0000015
Shop #: WSC 09416 444 57312
VCID: 63C5E124A2A7902603-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0070
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H44 0060
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303IO057507058
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 31695B6CA8DB72B6C1-8064
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H08 0050
Subsystem 2 - Serial number: 00000000225955
Subsystem 3 - Serial number: 0105.09.050000000100010495ÿ
Subsystem 4 - Serial number: 010495ÿ
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 99
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 13:30:30
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2016.04.26
Time: 17:19:36
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000030052292
Coding: 0000040
VCID: 5BB5D9C49AD7A8E64B-800E
1 Fault Found:
01853 - Heated Seat; Left Front (Z45)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 12:34:15
Freeze Frame:
Temperature: 24.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 C HW: 4F0 907 279 A
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0114123
VCID: 2959B30C800B0A7609-807C
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7231553
Shop #: WSC 00000 000 00000
VCID: 1C379AD8DF59EFDE82-8048
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0300
Revision: 12H29000 Serial number: 00359D0A3CT+
Coding: 0013878
Shop #: WSC 09416 444 64081
VCID: 2A5B4C00850D016E00-807E
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME0A507B4EC
Subsystem 3 - Serial number: 6342CSME47406C689
Subsystem 4 - Serial number: 6352QSME056E267DU
Subsystem 5 - Serial number: 6362QSME056D3945N
Subsystem 6 - Serial number: 63734SME0649366F7
Subsystem 7 - Serial number: 63834SME064D327F9
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025052440307
Coding: 0012041
Shop #: WSC 02323 785 00200
VCID: 66C3F8305195E50EE4-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 980 N
Component: KOMBIINSTR. M73 H16 0630
Revision: 00100000 Serial number: 4PY34GG95
Coding: 2113263
Shop #: WSC 59633 001 104857
VCID: 2149AB2CF83BC23651-8074
Address 19: CAN Gateway Labels: 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008059108119
Coding: ECFE73CC1B7B04
VCID: 275DB534961F3C061F-8072
4 Faults Found:
02230 - Digital Radio (DAB) (R147)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 12:35:11
00465 - Control Module for Telephone/Telematic (J526)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 13:27:02
00380 - Special Vehicle Control Module (J608)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 13:28:19
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2016.04.26
Time: 17:18:57
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 61C9EB2CB8BB823611-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H45 1100
Revision: 00000000 Serial number: 355IZ057553835
VCID: 387F66484BA1A3FE86-806C
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0080
Revision: 00000000 Serial number: Q”
Coding: 0051947
Shop #: WSC 98765 666 36433
VCID: 2C574A188FF91F5EF2-8078
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2016.04.26
Time: 17:18:57
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H19 0140
Revision: 01400019 Serial number: 01006945090000
Coding: 4618301
VCID: 2E534010B9E56D4EDC-807A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
01696 - Footwell Lighting; Rear Left (W45)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2016.04.26
Time: 17:17:58
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000803640
Coding: 0000026
VCID: 2541BF3CEC132E162D-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000006747
Coding: 0012114
VCID: 5EB3D0D089C5BDCE2C-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0080
Revision: 00000000 Serial number: I‡•
Coding: 0051947
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2016.04.26
Time: 17:18:57
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0006022
VCID: 5DB1D7DC84C3A6D635-8008
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 2643B8309115250E24-8072
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394I 057613775
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000109518
Shop #: WSC 09416 444 999999
VCID: 2345A124E227D02643-8076
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 350214E1T1
Coding: 344630393135313035442056413033353032313445315431
Shop #: WSC 42317 001 1048576
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000509060282
Shop #: WSC 12336 024 394758
VCID: 3467527857C9479EAA-8060
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0051754
Address 75: Telematics
Cannot be reached
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0030
Revision: 00H09000 Serial number: 11720525504548
Coding: 0001206
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H13 1130
Revision: 00000000 Serial number: 00000007541641
Coding: 0010970
VCID: 285FB6089B01337E16-807C
End-------------------------(Elapsed Time: 02:46)--------------------------
Ross-Tech: Home
Coding: 0007772
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:12
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 76.0°C
Voltage: 12.573 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:15
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: 26.0°C
Voltage: 11.303 V
Coding: 0000002
Coding: 0021352
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 12:34:39
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x019E
Hex Value: 0x00FF
Coding: 0000015
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 99
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 13:30:30
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2016.04.26
Time: 17:19:36
Coding: 0000040
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 12:34:15
Freeze Frame:
Temperature: 24.0°C
Coding: 0114123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Cannot be reached
Coding: 0013878
Coding: 0012041
Coding: 2113263
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 12:35:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 13:27:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 165979 km
Time Indication: 0
Date: 2005.02.01
Time: 13:28:19
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2016.04.26
Time: 17:18:57
Coding: 0082954
Coding: 0051947
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2016.04.26
Time: 17:18:57
Coding: 4618301
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2016.04.26
Time: 17:17:58
Coding: 0000026
Coding: 0012114
Coding: 0051947
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 139
Mileage: 165979 km
Time Indication: 0
Date: 2016.04.26
Time: 17:18:57
Revision: C63C0030
Coding: 0006022
Coding: 0000016
Coding: 0000002
Coding: 0051754
Coding: 0051754
Cannot be reached
Coding: 0001206
Coding: 0010970
The AC works perfectly, one of the drains was bent, and that was repaired and checked by the dealership at the last visit, one of the tests they did was leave the AC running for 3 hours, no water.
The problem was actually the unibody seals, replaced them and no more water in the car!![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Thanks
mknight
15
06-09-2021 03:58 PM
MNLINDSEY
07-16-2013 12:00 PM
Bkong
05-11-2007 07:40 PM
