When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
2006 A6 quattro 3.2 Rear Wheel Bearing replacement
Hi all,
I want to replace the rear wheel bearing for my 2006 A6 quattro 3.2 and i couldn't find any tutorials for DIY.
I got a quote from an Audi dealer for the Part #: 4F0598625A for $194. Is it hard to replace it? Do i need to press the bearing into the hub? Is there a service manual describing this procedure?
No experience w/rear wheel bearing failures on '06 A6 Avant w/221K (Sold) or '07 w/156K or '08 w/163K BUT '06 had new front wheel bearings installed between 165-175K. My '08 just needed new front wheel bearings at 160K. Symptoms were high pitched whine I first associated with noisy tires from lack of timely rotation. Left front was really noisy & got worse when turning! Got new wheel bearings from emiparts.com ($210) and had installed by local mechanic mechanic. ($275). Much quieter now!
Thank a lot for any input.
I had to replace the front bearing on my 2006 A6. I think it is much more difficult compared to the old cars. The iron bearing is held in aluminum hub and dissimilar metals corrode and fuse together. I ended up bringing the car to the shop.
Not sure if the rear hub is aluminum or iron. also the rear hub could be easier to take of the car and bring to the guys with the press.
Apart from the whining, did you ever experience light vibration/shaking at highway speeds?
This has been going on for awhile, and I'm trying to narrow it down. I've gotten under the car to check: axles/boots, upper lower arms, shocks and everything is still in great condition. Don't know if on of the wheels bearings are bad?
If you follow the Bentley Repair manual, here is what is states to R&R to remove the wheel bearing housing:
Wheel Bearing Unit
Special tools, testers and auxiliary items required
Torque Wrench V.A.G 1332
Removing
Vehicles with coil springs
All Wheel Drive (AWD)
Remove wheel covers, remove cover cap on light-alloy wheels (removal hook in vehicle tool kit).
Loosen collar bolt for outer joint of drive axle (only loosen when vehicle is standing on its wheels "Risk of accident" ). Refer to Drive Axle Outer Joint Collar Bolt, Loosening and Tightening.
Remove coil spring.
Refer to Coil Spring .
Remove wheel speed sensor - 3 - . Refer to Brake System - Repair Group 45 .
Remove drive axle. Refer to Drive Axle .
Place vehicle on a hoist. Refer to Positioning Vehicle on Hoist and Wheels .
Drive Axle
Removing
Loosen collar bolt for outer joint of drive axle. Refer to Drive Axle Outer Joint Collar Bolt, Loosening and Tightening .
Remove coil spring. Refer to Coil Spring .
All vehicles
Remove exhaust system rear muffler. Refer to Engine Mechanical - Repair Group 26 .
Remove rear final drive. Refer to Rear Final Drive 0AR - Repair Group 39 or Rear Final Drive 01R - Repair Group 39 .
I did feel some vibration which increased w/speed and got worse when turning right. (left ront bearing was worst)
I tried to train myself in a U pull it yard on a similar Audi and it’s not easy at all. I don’t have the tools to be able to replace it myself. I’m waiting for a quote from a shop.
so far it’s just the noise it makes, I checked if it has any play and it seems ok.
