2006 Audi A6 3.2 Fuel Problem
I have a 2006 Audi A6 3.2 with the following issue:
012403 - Fuel Pump Circuit
P3073 - 007 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 7
Reset counter: 40
Mileage: 268375 km
Time Indication: 0
Date: 2005.10.04
Time: 19:03:33
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 24.0°C
Engine Off
Pressure: 7.0 bar
Speed: 0.0 km/h
012425 - Signal Line for Fuel Pump Electronics
P3089 - 007 - Electrical Malfunction - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 4
Fault Frequency: 52
Reset counter: 40
Mileage: 268375 km
Time Indication: 0
Date: 2005.10.05
Time: 19:36:53
Freeze Frame:
RPM: 0 /min
Temperature: 19.5°C
Engine Off
Pressure: 0.7 bar
Speed: 0.0 km/h
Fuel pump or fuel pump regulator?
Car will not keep running.
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 40
Mileage: 268375 km
Time Indication: 0
Date: 2005.10.04
Time: 19:03:33
Freeze Frame:
RPM: 0 /min
Temperature: 24.0°C
Engine Off
Pressure: 7.0 bar
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 52
Reset counter: 40
Mileage: 268375 km
Time Indication: 0
Date: 2005.10.05
Time: 19:36:53
Freeze Frame:
RPM: 0 /min
Temperature: 19.5°C
Engine Off
Pressure: 0.7 bar
Speed: 0.0 km/h
-1)) { fetch_object('currentPost').scrollIntoView(true); }" onpageshow='event.persisted && (function(){var allInstances = CKEDITOR.instances, editor, doc;for ( var i in allInstances ){ editor = allInstances[ i ]; doc = editor.document; if ( doc ) { doc.$.designMode = "off"; doc.$.designMode = "on"; }}})();'>
- I found a blown 20Amp fuse in the passenger side fuse panel for the Electric Fuel Pump.
After testing it with my meter there is a direct short in this circuit that will continue blowing fuses.
I measured across the connector of the fuel pump in the tank and it measured 0 ohms which I assumed was a shorted fuel pump.
I just replaced the fuel pump with a new one and have the same results.
Now I am finally thinking it may be the fuel pump control unit module that is mounted with a big pigtail connector next to the fuel pump.
Any help or advice would be appreciated.
-dave
Woops Sorry...
-dave
-dave
