2008 Audi A6 Cylinder Misfire/EPC Light
Hey guys,
I was driving about 90 mph on 9/5/16 and my EPC, ESP and flashing check engine light all came on, so I pulled to the side of the e-way, turned the car off, and waited 15 mins or so. After turning the ignition to position two, all lights were off, so I started the car and drove home (about 4 miles), no issues.
Here are the faults from that day:
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F2 910 559 H HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0040
Revision: --H20--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 25169 444 58785
VCID: 316E8DEBA83AFDB6E2-8064
10 Faults Found:
000772 - Cylinder 4
P0304 - 006 - Misfire Detected
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 174563 km
Time Indication: 0
Date: 2016.09.05
Time: 19:18:30
Freeze Frame:
RPM: 864 /min
Mass Air / Rev.: 376.1 mg/str
Temperature: 37.5°C
Idle
Time: 25.6 s
Speed: 3.0 km/h
004874 - Cylinder Disabling
P130A - 006 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 174563 km
Time Indication: 0
Date: 2016.09.05
Time: 19:18:31
Freeze Frame:
RPM: 960 /min
Mass Air / Rev.: 337.9 mg/str
Temperature: 37.5°C
Time: 0.00 s
Speed: 3.0 km/h
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 174563 km
Time Indication: 0
Date: 2016.09.05
Time: 19:18:31
Freeze Frame:
RPM: 1024 /min
Temperature: 37.5°C
Idle
Load: 49.4 %
Speed: 3.0 km/h
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
Shop #: WSC 02325 758 00200
VCID: 66C42EB751746A0EC7-8032
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 167
Mileage: 174563 km
Time Indication: 0
Date: 2016.09.05
Time: 19:18:30
Freeze Frame:
Hex Value: 0x8600
Hex Value: 0x4006
Hex Value: 0x0025
Hex Value: 0x01A9
Hex Value: 0x00FF
When the car was started the next morning (9/6) it was an extremely rough idle and the same lights came on again. Here are the faults for that day:
000771 - Cylinder 3
P0303 - 007 - Misfire Detected
Freeze Frame:
Fault Status: 00000010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.06
Time: 07:49:43
Freeze Frame:
RPM: 832 /min
Mass Air / Rev.: 256.2 mg/str
Temperature: 40.5°C
Idle
Time: 51.2 s
Speed: 0.0 km/h
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 006 -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.06
Time: 07:49:43
Freeze Frame:
RPM: 832 /min
Temperature: 40.5°C
Idle
Time: 51.2 s
Speed: 0.0 km/h
After reading a ton of forums, the crankshaft position sensor sounded like a reasonable suspect. After changing it, I started the engine again (9/9) and the following faults appeared:
005430 - Camshaft Timing Adj. Bank2 (N208)
P1536 - 009 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00000100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.09
Time: 19:34:21
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 33.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
005416 - Camshaft Timing Adj. Bank1 (N205)
P1528 - 009 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.09
Time: 19:35:09
All the faults above were stored on the computer, as I did not have access to VCDS until 9/15/16. After reading the faults, I performed resistance checks on all coils and coil harnesses, replaced all spark plugs, and cleared all DTC's. I then started the engine and again read the following faults:
Address 01: Engine (AUN) Labels: None
Part No HW: 4C1 907 55< E
Revision: --H20-(- Serial number: % %
VCID: 55A6197BFC12F1965E-8000
Subsystem 5 - Part No: 4F7 910 559 M
Component: 3.2l%V6 FSI% % 0040
Shop #: WSC 90705 446 58785
3 Faults Found:
000772 - Cylinder 4
P0304 - 003 - Misfire Detected
P130A - 006 -
P1653 - 008 -
Readiness: 0110 0000
Coding: 0020895
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.15
Time: 20:35:25
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0025
Hex Value: 0x01A5
Hex Value: 0x00FF
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000080031
Shop #: WSC 22103 444 84447
VCID: 234277A3E2C65F2660-8076
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2705240263
Coding: 344630393135313035442056413032373035323430323633
Shop #: WSC 00000 384 00290
1 Fault Found:
02276 - Quiescent Current Stage 5
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.15
Time: 20:34:30
New to the forum, however, I have done extensive research through other forums and have found a lot of similar info. Not trying to repost the same information, but I don't know an alternative. I also have ran into the typical vacuum line failure near the head that runs to the evap canister and have replaced it.
Any suggestions or input would be awesome! Thanks in advance!!
10 Faults Found:
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 174563 km
Time Indication: 0
Date: 2016.09.05
Time: 19:18:30
Freeze Frame:
RPM: 864 /min
Temperature: 37.5°C
Idle
Time: 25.6 s
Speed: 3.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 174563 km
Time Indication: 0
Date: 2016.09.05
Time: 19:18:31
Freeze Frame:
RPM: 960 /min
Temperature: 37.5°C
Time: 0.00 s
Speed: 3.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 174563 km
Time Indication: 0
Date: 2016.09.05
Time: 19:18:31
Freeze Frame:
RPM: 1024 /min
Temperature: 37.5°C
Idle
Load: 49.4 %
Speed: 3.0 km/h
Coding: 0020895
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 167
Mileage: 174563 km
Time Indication: 0
Date: 2016.09.05
Time: 19:18:30
Freeze Frame:
Hex Value: 0x8600
Hex Value: 0x4006
Hex Value: 0x0025
Hex Value: 0x01A9
Hex Value: 0x00FF
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.06
Time: 07:49:43
Freeze Frame:
RPM: 832 /min
Temperature: 40.5°C
Idle
Time: 51.2 s
Speed: 0.0 km/h
P0300 - 006 -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.06
Time: 07:49:43
Freeze Frame:
RPM: 832 /min
Temperature: 40.5°C
Idle
Time: 51.2 s
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.09
Time: 19:34:21
Freeze Frame:
RPM: 0 /min
Temperature: 33.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.09
Time: 19:35:09
3 Faults Found:
000772 - Cylinder 4
P130A - 006 -
P1653 - 008 -
Coding: 0020895
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.15
Time: 20:35:25
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0025
Hex Value: 0x01A5
Hex Value: 0x00FF
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 174571 km
Time Indication: 0
Date: 2016.09.15
Time: 20:34:30
Welcome to the forum, your issue sounds like it could be one of a few things ranging from hpfp to injectors... Take a look at this thread and you might be able to apply it to what your experiencing:
ESP EPC & Engine Light ON - AudiWorld Forums
Also, any reason for the ABS to throw a fault? Or is it unrelated?
Thanks for the input raj99! It looks like they mostly had connection issues on the throttle body and/or intake manifolds. I will attempt to troubleshoot more this evening by looking for loose/broken connections and report my findings. Could this possibly be caused by a stuck valve? I am considering a Seafoam cleaning, but am not sure if this is a mechanical issue or an electrical one, but I am leaning towards electrical.
Today after work, I stopped at the Audi dealer to pick up some things and I brought my issue up to a couple of the service technicians. They recommended that after swapping coils and finding no change, the fuel injectors were the next place to look. I began by swapping the ignition coils to see if the misfire would follow...no luck. After I had ran the engine for a few minutes, I moved on to pulling my cylinder 4 spark plug (brand new), and I found that the plug was covered in gas and it definitely had never fired. I then disconnected all coil packs from their harnesses and removed an additional spark plug to use as my control (clearly had burned correctly). I had my brother crank the engine over and noticed that cylinder 4 pushed out a visible mist of fuel, where cylinder 5 did not. I tested it once more to be certain and the outcome was the same. This has led me to the conclusion that my fuel injector is stuck in the open position at cylinder 4 and is flooding the cylinder with fuel.
Before I take the plunge and replace/clean/swap the fuel injectors, could someone please attempt to punch holes in my theory or tell me why I am wrong? Or if there is additional testing that can be conducted?
All input is welcomed and appreciated!!
I'm having problems with the Audi A6 quattro TFSI 2009. Can anyone help me ..... I'm getting crazy .... rs
The car works perfectly until reaching 6,500 rpm and then ascends the lights of ESP, injection and other .......
Has anyone ever experienced this?
Hi L&G
I’ve been looking up the whole internet for Audi A6 C6 3.2L Quattro 2006 graphics or photos of engine to see where the timing mark is that pulley notch needs to be aligned? On my engine I have found the notch, but can’t find timing mark arrow or any sign where I would be aligning the notch on the pulley.
Pics would be highly appreciated,
Thanks in advance.
Thanks in advance.
I did not see hpfp failure that you are referring to. Also, after troubleshooting today I have concluded that Seafoam will not help me, as you have stated.
Were you able to solve the problem?
I have the same problem!
Thanks if you want to help me.
Att;
Frequentflyer
10-09-2018 01:53 AM
rdzski@123
04-15-2018 11:21 AM
kenfforsythe
07-08-2010 10:47 AM
Seredni
01-07-2004 08:57 PM
