Last edit by: IB Advertising
- Audi A6 C6 Transmission Diagnostic Guide<br>Guide to diagnose trouble and recommended solutions.
A6 3.2 3rd gear slippage...
I bought an '06 A6 Avant 3.2 with 60K miles on it a little over a month ago. The is the first car I have owned with an automatic transmission. (This is my 5th Audi) I notice that when accelerating at a mild pace, when the car changes from 2nd into 3rd gear, it seems to slip for a second or two before fully engaging 3rd gear. Almost seems like there is a half gear in there. If I accelerate more briskly, and the transmission shifts into 3rd from a higher RPM, it engages quickly and does not slip at all. I am starting to think this is a feature of the transmission to make low RPM shifts smoother without too much of a drop in RPM, bringing the motor out of it's better torque range... but I am not sure.
Can anyone else verify that their car does this as well, or if this is something that perhaps could be fixed with a software update or Auto Trans Fluid change?
Thanks-
Thanks-
Search for adaptive transmission learning reset. I can't recall exactly how to do it. Someone had a way to do it with the gas pedal I think. There might be a VCDS reset for it also also. Good to try that first and see if it helps.
It might be locking of torque converter at light throttle.
Torque converter will not lock at heavy throttle.
If you have a VAG-COM, you will be able to see status of the gear and the torque converter.
my 4.2 is at dealer right now for similar reason. when decelerating i was getting a bump or slight jerking between 4th to 3rd. After finally replicating issue dealer had to consult AOA. they pulled data points from ecm and trans control module and found that it was a learning issue. They ultimately wiped the memory and reloaded. So when i pick it up it will adapt to my driving style all over again. They felt as though it may have to do with previous owners style versus mine. My only problem with that train of thought is to wonder why it happens now. I've owned the car since June 09. Now granted I do drive based on mood so my aggression and use of S mode or Tiptronic varies but I still wonder. They said there was nothing mechanical so I guess I'll have to see how it plays out. Hope this helps
Dealer is doing it. I imagine it requires removal of the control units and some sort of hookup to VAGCOM. Or maybe not. I'm under CPO so there is no cost for me. I imagine there would be hourly diagnostics for this but arguably AOA should cover under a TSB if enough customers are having this issue. where do you live?
My car is going to my mechanic for an oil change tomorrow, I'll have him do some vagcom research and see if anything pops up.
