A6 Avant 2004, Hatch won't open with latch-only w/remote
I check the threads and couldn't find this issue. The rear hatch will not open with either the hatch handle or the release on the drivers door. The only way it opens is with the trunk release button on the ignition key. That being said it's hard for me to determine if it is a mechanical or electrical problem. Any ideas? Any chance something simple like a VAG setting or a fuse?
you might try fiddling witht the Valet mode.
Not that familiar with the Avant, but you may have a key switch on the hatch in addition to the valet button on the dash.
I had a similar issue and found my trunk switch was thrown.
good luck
good luck
Kristi James
03-17-2019 08:16 AM
SGTaylor
04-20-2005 06:41 AM
