A6 (C6) 2006 - DVD Navigation device Problem
Hello... I am Denis from Bulgaria.. new user. Just registered.
I have one problem. From about 2 months i am proud owner of Audi A6 (C6) 3.0 TDI 2006. It happens that the DVD Navigation is not working. There is a disk with the navigation inside but it don't want to read or eject it. I have been in Audi's services to unlock the device but it still don't want to eject or read the DVD with the navigation. One friend told me to remove it and give it to some service or clean it my self.
The problem comes when i try to remove the device. It looks like i can't pull it out of that black metal place (where it's sitting) to remove the cables that are plugged in it. Could you please give me a hint how exactly i can remove the device because i can't reach it from the back to un-plug the cables. Is there a possible way to remove the black metal side so i can see and reach what's at the back of the device?
Here on the image you can see the maximum that i can pull it out before the cables at the back stops it: IMAGE
Thank you
Thank you
Thank you
Thank you
I am not sure how you are going to clean the unit or how it would help.
Yes. As i said the device has been unlocked.
I will most likely give it to some service for electronics. You just give me information on how to remove it from there.
Nope.. Nothing..
The only thing is that if i try to put a DVD inside it won't get it and in the same time if i push the NAV button the MMI says "PLease check navigation DVD"
I was in Auto's service actually and they told me that there is some problem, but they are not autorized to fix it. They can only replace it, but i want to take it off to try to fix it.
Isn't there a way to remove that device?
When i push the NAV button it says "Please check Navigation DVD" which according the the MMI Manual means that there is no disk inside. But when i try to put a DVD disk in the device it wont get it. Also when the device is OFF and i push the button it starts spinning (i can hear it). So i guess there is a disk inside but its stuck and it don't want to read it.
I just want to remove that device from there to take it to some service.
Isn't there anybody that have experience removing that thing. I can't reach the damn cables to unplug them from the back.
Thanks
Thanks
Don't know about the lock but I am sure that cleaning helps.
Mine did that once and when I took out the NAV Disk, it was pretty dirty (Nobody had soiled it, I think it got dirty by itself sitting in the trunk!!)
Cleaned it with a microfiber cloth and it is same as new !!!
Good luck
