ABS module bad? Would like second opinion.
Usual suspects - ASC indicator light on, ABS indicator light on, Brake Light indicator flashing, getting parking brake warning symbol in the console display. VAG gives me a total of four codes related to the ABS controller (see below).
Looks like it's time to pull the ABS module and send it off to Module Masters. Or is there something else I should be looking at?
Thx
-K2
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0060
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 02325 785 00200
VCID: 2A50DFD485DF374EE53-807F
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 40
Mileage: 172975 km
Time Indication: 0
Date: 2014.03.19
Time: 08:32:27
Freeze Frame:
RPM: 896 /min
Mass Air / Rev.: 92.7 mg/str
Temperature: 67.5°C
Idle
Load: 12.2 %
Speed: 0.0 km/h
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 2D5AD4C8B4312076001-8078
3 Faults Found:
01418 - Switch Valve 1 for Electronic Stability Program (N225)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 193
Mileage: 173718 km
Time Indication: 0
Date: 2014.04.05
Time: 18:51:08
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x47A2
Hex Value: 0x0016
Hex Value: 0xC090
Hex Value: 0x00FF
01419 - Switch Valve 2 for Electronic Stability Program (N226)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 184
Mileage: 173592 km
Time Indication: 0
Date: 2014.04.02
Time: 07:38:07
Freeze Frame:
Hex Value: 0x4500
Hex Value: 0x4006
Hex Value: 0x0017
Hex Value: 0xB5AA
Hex Value: 0x00FF
01421 - High Pressure Switch Valve 2 for Electronic Stability Program (N228)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 193
Mileage: 173718 km
Time Indication: 0
Date: 2014.04.05
Time: 18:51:35
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x0019
Hex Value: 0xC094
Hex Value: 0x00FF
Thx
-K2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 40
Mileage: 172975 km
Time Indication: 0
Date: 2014.03.19
Time: 08:32:27
Freeze Frame:
RPM: 896 /min
Temperature: 67.5°C
Idle
Load: 12.2 %
Speed: 0.0 km/h
Coding: 0020895
3 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 193
Mileage: 173718 km
Time Indication: 0
Date: 2014.04.05
Time: 18:51:08
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x47A2
Hex Value: 0x0016
Hex Value: 0xC090
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 184
Mileage: 173592 km
Time Indication: 0
Date: 2014.04.02
Time: 07:38:07
Freeze Frame:
Hex Value: 0x4500
Hex Value: 0x4006
Hex Value: 0x0017
Hex Value: 0xB5AA
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 193
Mileage: 173718 km
Time Indication: 0
Date: 2014.04.05
Time: 18:51:35
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x0019
Hex Value: 0xC094
Hex Value: 0x00FF
If I remember correctly, MM gives you a 5yr warranty, while Cheap-Abs gives you a lifetime warranty. Also, I believe Cheap-Abs is less expensive. Check it out though, my memory may not serve me correct.
Correct, MM is 5yrs. Lifetime sounds great as we now know this issue can come back. Got my module back from MM warranty work and installed today. All back to normal and all lights are gone. Good luck with yours.
dakota137
04-16-2011 01:36 PM
JacobB
06-17-2007 09:08 PM
BoostFrenzy
10-06-2006 04:34 AM
nt2old4ns4
05-19-2006 05:44 AM
Ok, have the VAG hooked up to my car with the ABS light on. Can't connect at all with the ABS proble
S4Del
12-12-2003 04:23 PM
