Adaptive Air Suspension - compressor and relay J403
The adaptive air suspension is showing erratic behavior I can't figure out. Some ok for quite some time, sometimes it drops all the way down on one corner.
Various, changing error codes (all of those listed in the TSB 430816 2018765/3).
I want to first change the relay in question J403.
Where is it located?
DIY how to get there (found indication it might be hidden behind the passenger side glove box)?
Preparing for the next step:
DIY how to get the compressor and valve block out?
Overview of relay carrier
1 - Relay carrier in electronics box, right in plenum chamber
q Position of relays, from model year 2005 → page 803/7
q Position of relays, from model year 2007 → page 803/8
1 - Vacant
2 - Adaptive suspension compressor relay -J403-
2.1 - Vacant
2.2 - Vacant
3 - Glow plug relay -J52- (Diesel), automatic glow period control unit -J179- (Diesel), secondary air pump relay -J299- (petrol)
4 - Vacant
1 - Vacant
2.1 - Vacant
2.2 - Vacant
4 - Vacant
Plenum chamber = box in engine bay, under windshield drain cover, in front of fire wall.
Right side box also houses ECU.
There are 2 relays both with 373 stamped on them.
Both are part number 8D0951253C.
Which one is the adaptive air suspension (compressor) relay?
I read that the 373 is interchangeable with 204 and 214. Can someone confirm?
![Name: IMG_00052_zps07de4fb2.jpg
Size: 139.4 KB](https://www.audiworld.com/forums/attachments/a6-s6-c6-platform-discussion-58/78712d1501278852-adaptive-air-suspension-compressor-relay-j403-img_00052_zps07de4fb2.jpg)
![Name: IMG_0006_zpsb117b2ea.jpg
Size: 108.3 KB](https://www.audiworld.com/forums/attachments/a6-s6-c6-platform-discussion-58/78713d1501278852-adaptive-air-suspension-compressor-relay-j403-img_0006_zpsb117b2ea.jpg)
![Name: IMG_0007_zps58e1135d.jpg
Size: 53.8 KB](https://www.audiworld.com/forums/attachments/a6-s6-c6-platform-discussion-58/78714d1501278852-adaptive-air-suspension-compressor-relay-j403-img_0007_zps58e1135d.jpg)
![Name: IMG_00082_zps7d5ae697.jpg
Size: 75.6 KB](https://www.audiworld.com/forums/attachments/a6-s6-c6-platform-discussion-58/78715d1501278852-adaptive-air-suspension-compressor-relay-j403-img_00082_zps7d5ae697.jpg)
![](http://i1273.photobucket.com/albums/y407/KraftwerkTurbo/IMG_00092_zps35cd42d3.jpg)
![](http://i1273.photobucket.com/albums/y407/KraftwerkTurbo/IMG_00102_zpsce6501de.jpg)
best regards
Andy
I found that in my case the reason for the water migration into the Plenum was a improperly fitted ECU cover. The outboard aft corner left a gap right where the windshield wiper close out panel met this cover. I had never had this cover off so possibly a dealership issue. Its worth a look. The ECU Cover is a major pain to put back in and have it seal properly.
