A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Adaptive Air Suspension - compressor and relay J403
Old 02-08-2017, 09:06 AM
  #11
lasztam's Avatar
Not the best pic...but it might work for this question...
Old 02-08-2017, 09:41 AM
  #12
lasztam's Avatar
This comes for the same car...this shows front position.
Old 02-08-2017, 09:42 AM
  #13
lasztam's Avatar
But regarding this...the right relay is the one...
Old 05-03-2019, 04:03 AM
  #14
Paul Andersson's Avatar
Default Bump
Hi sorry for bumping this old topic
but i have the same problem compressor probably burnt because of relay car pumped intil battery dead and I heard the compressor struggeling and then a hiss like a airline blew so hoping the compressor made it. I am going to lift the car this weekend but for now i have a question. I took my relay out (to late) and cant remember the orientation
Thx
Old 05-03-2019, 09:34 AM
  #15
A6Gary's Avatar
Normally, relays can only be inserted into their socket in one orientation due to the spade orientations and width. Also, the relay number, e.g., "970", is usually aligned so it is directly readable with the cover off.
Old 06-18-2019, 07:55 PM
  #16
christianaudi's Avatar
Thank you. what is this source?
Old 08-24-2022, 11:39 PM
  #17
Lnc
Lnc's Avatar
Default How do you get to relay
Originally Posted by vtraudt
Plenum chamber = box in engine bay, under windshield drain cover, in front of fire wall.
Right side box also houses ECU.
There are 2 relays both with 373 stamped on them.
Both are part number 8D0951253C.
Which one is the adaptive air suspension (compressor) relay?
I read that the 373 is interchangeable with 204 and 214. Can someone confirm?
Attachment 78712
How do you get to these relays I have a australian right hand drive 2007 audi a6 allroad diesel trying to locate air compressor relay
Attachment 78714
Attachment 78715
Old 08-25-2022, 08:50 PM
  #18
A6Gary's Avatar
Due to a water leak into the ECU electrical box, I recently had to replace relay J403. To access, your have to do the following: 1. Remove the plenum cover. 2. Remove the wiper arms. 3. Remove the two Torx screws and then the plastic lower windshield edge (snaps in-place along the bottom of the windshield. 4. Remove the Torx screws (I believe there are 5 total) that secure the ECU cover, and then remove the cover on the passenger side of the plenum. The relay is located to the right and below the ECU.
100A8
12-26-2014 08:31 PM
Waj786
Q7 MK 1 Discussion
09-12-2014 08:46 PM
efmack1270
09-24-2013 10:28 AM
gtreng1
01-03-2013 10:33 AM
Moab
Audi allroad
10
09-30-2007 05:57 PM
Quick Reply: Adaptive Air Suspension - compressor and relay J403
