Last edit by: IB Advertising
- Audi A6 C6 How to Align Adaptive Headlights<br>Step by step instructions for do-it-yourself repairs.
Adaptive Headlight Defective
Hello there,
I was driving my 2008 Audi A6 two days ago when I got this error on my dashboard and the Adaptive Lights (both) stopped working.
I've read alot of threads which all said the same two things, change the control model or the entire front headlight unit.
after scanning my Audi with VCDS, the problem was the left headlight motor, I read somewhere on the internet that 2005~2008 headlights (no LED strip) motor can be changed alone without changing the entire unit and I found this:
http://genuineaudiparts.com/parts/20...Adjust%20motor
anybody here can give me some information? my warranty is out and a new headlight unit will cost 1200$
Can I change the motor alone?
Before you do anything call your dealer and see if Audi will replace it. I got the same message on my 2005 just a few months ago and the dealer replaced the entire unit for free.
You can NOT change the adaptive headlight motor. That motor is for horizontal movement and is built into the headlight housing. You CAN change the vertical self leveling motor, which all Xenon headlights must have per regulation. The error message on you dashboard is probably for the horizontal motor, however, when you scan the car with VCDS it should tell you which motor is bad, maybe you will get lucky.
FWIW, I had this problem a few years back, when I opened the rear headlight housing door, I noticed the wires were frayed causing a short. So I carefully taped the wires and it lasted for about a year. When the errors messages stared coming back I replaced the entire unit with a used one for $100. If you are getting "Open or Short circuit" errors, take a look at the wiring.
Can you check your invoice and see what was the warranty code the dealer used?
Thanks.
I have a friend at the dealer here, so I went and scan my car there with VAS.
error went "Left Cornering Motor Open or Short Circuit" my car is 2008 with the pre face-lift headlights which I can change the motor for cornering without changing the entire unit.
after getting the headlight out, the motor is next to the Xenon Starter and all you need to do is unscrew 2 screws and the motor is out.
using the same part number I got the new Motor and installed it, delete all the faults and start the scan again...I got the same Error!
so I swapped the Left/Right Headlight and repeated the scan, I got en Error on the Left Motor which was connected to the Right Headlight!?
after that I tried a new headlight unit from the dealer, after moving the missing parts (Control Modules, Xenon Bulb + Starter) and repeated the scan...it went OK.
It seems that the wires inside the headlight is causing the problem assuming that the Motor is ok, I checked every wire I can see from the back of my headlight it seems ok!
1.Do u think I can do anything to the headlight before deciding what to do?
2.Why the car still give the same Error after Swapping Left/Right?
new headlight will cost me 1200$, any reliable source to get used cheaper housing?
The cornering motor is the thing labeled "MF13" in your picture. I can pretty much guarantee that the wiring is split and shorting or broken. The headlights are branded Hella. You might be able to get new wiring from them. I have the same issue and have attempted to repair it twice by completely disassembling the headlight and repairing the wiring. The problem I've had is the more I fix the wiring the more the wiring falls apart. I've given up on repairing it.
I agree with dafrazi, first of all, I am pretty sure you replace the self leveling motor and not the cornering motor, second, once the wiring starts to go it is difficult to completely repair it. I purchased a used unit from an accident low miles but broken tabs, I fabricated tabs and installed the unit and have not had any issues then
That is NOT the corning motor that is labeled in the photo. The cornering light is internal and can not be replaced. Best bet, find a used one at a junk yard with return policy. I paid $550 just to be able to remove the piece of electrical tape from my display.
