Anyone change a parking brake control module in C6?
Dealer wants 450, but genuinevwaudiparts.com has the part for 250. Anyone have any experience swapping this part out?
I just dropped 2k on a new ABS control module, dont want to give the dealership anymore of my hard earned cash..
Its a 2005 A6 4.2L
Its a 2005 A6 4.2L
According to Bentley it's located in the right rear luggage compartment. In the side compartment below the tools. Instructions just indicate a straight forward replacement. (Doesn't even say you need to disconnect the battery...which they tend to say for everything.)
Removing
Remove side trim in luggage compartment at right rear
Body Interior - Repair Group 70
Unscrew nuts - tightening torque 10 Nm
Remove item - EPB control module with connection.
Pull locking slider up and disconnect connector.
Installing
Installation is reverse of removal, noting the following:
If control module is replaced, select the function "Replace" of respective control module in "Guided Fault Finding" .
Diagnostic Operation System VAS 5051A
Removing
Installing
Hi ncarvain,
the parking brake malfunction indication on my dash is on and the dealer says i need to replace the control module. Do you have the part number to buy it from genuineaudiparts.com? and how did the replacement go? Is there any coding involved post replacement?
I hear it is very simple to do, which it sounds like it is. I believe i read some where its located under the tool kit in the trunk. Speaking with an audi parts seller, i was told that they have already sold over 100 units this year. So it seems to be a common problem; however so far I cant find anyone who has actually done it.
