Anyone change a parking brake control module in C6?
#12
Did anyone figure out where the EPB control module located? The Bentely manual just says 'remove right side trim in luggage compartment. Interior group 70'
#14
nothing special, i dont remeber the size of the screw heads. there are three to remove the carrier for the jack and i believe 2 for the tool carrier. then u will see the brake module easy to remove and replace. There was a thread discussing this some time ago and i believe it has a better picture. now my experience is from when i had the '05, so maybe some monir changes to the '06 verson.
#16
It is real easy 10 mins or less
#17
I have a 2009 Audi A5 - My parking brake stopped working, checked with VCDS and it said that there was a faulty switch.
I change the ON/ OFF switch next to the shifter,It didn't work.I changed the brake light switch under the steering column. It didn't wok.
I ordered a used EPB ECU model # (8K0 907 801 E). It doesn't work. Tried VCDS and it doesn't recognize it.
Since I got it used I thought that its also faulty and purchased another one. The 2nd one also doesn't get recognized.
Does it require some sort of programming? I'm at a stand still now without ideas.
#18
drhaller
30
11-21-2019 10:50 PM
mikeshere443
Audi 100 / A6 (C4 Platform)
13
12-29-2008 10:25 PM
Grapeking
48
05-14-2008 07:41 AM
Nogaro Stg3
02-10-2007 05:45 AM
