Anyone upgrade from v6 brakes to v8 brakes?
I am thinking of upgrading the front brakes on my 2007 A6 avant 3.2l to those found on the v8 sedan. Has anyone done this b4? Any idea whats involved?
Is there a difference besides a small increase in disc diameter?
..if that's the only difference, I can't imagine the difference in performance would be that great - a change to more aggressive brake pads designed for higher operating temps would be just as effective.
If the calipers are bigger, that's probably worth looking into - but at that point, why not go for the S6 brakes?
Re: Is there a difference besides a small increase in disc diameter?
any info on the S6 brakes? I am only aware that v8 have larger diameter rotors. what i am trying to do is find a solution to the 20k rotor/pad intervals.
A good reason - I believe the calipers and pads for the V6 and V8 are the same...
..so I don't think that will change the rate of wear.
I just started looking at brake options myself, so if I find anything relevant I'll post it here..
347mm vs 321mm for fronts & 330mm vs 302mm for rears.
For complete conversion I think u'll need discs+pads+calipers+carriers. The killer is the rear caliper as it has the electric parking brake as well. It could be done as European-spec 3.2 w/S-Line+ package have the 4.2 brakes, but on balance I doubt u'll gain a lot as there'll be an increase in unsprung weight.
That's the thing I was wondering - are the calipers different? Or is it just the carrier?
I can't seem to get an answer on that. In theory, the 4.2 A6 should get the same brakes as the S4, given the speed and weight.
Re: That's the thing I was wondering - are the calipers different? Or is it just the carrier?
The calipers are different comparing the 4.2 & 3.2, as the part numbers aren't the same.
I don't think the S4 uses the same brakes as the A6 4.2. The brakes on the 4.2 is the same in design & construction as the 3.2, only bigger.
Has anyone retrofitted urs6plus brakes on their urs6?you might have different brakes over the pond??
AUDIS6DOIT
Audi Original "S" Cars
9
07-28-2008 06:05 PM
whosee
44
06-20-2007 09:24 AM
