Last edit by: IB Advertising
- Audi A6 C6 Quattro System Fluid Change<br>Step by step instructions for do-it-yourself repairs.
ATF change DIY
#11
So may be you can do it in independent shop as well.
#12
Depending on which fluid you choose to go with we have service kits that include the filter and gasket from 200 - 500. Obviously kits utilizing Genuine VW/Audi fluid are going to be more expensive.
Jason
Jason
#14
Finally changed my tranny fluid, wow what a difference! The old stuff was smelly and very dark coming out. I did not change the filter nor did I drop the pan and only changed about 4 liters. When I drove the car it shifted smoother and had a more instant throttle response. Seeing as how ugly the old fluid was I'll do it again in 20k, and maybe every 20k till the car dies.
#15
#16
I have 69k miles on my 2005 with no previous ATF changes and no software updates. Shifting is ok but there is a slight shudder when downshifting from 2-1 or 3-2 coming to a stop. Do you recommend just a drain and fill at this point with the SP or should I do a filter change as well, and then follow up with drain and fills further down the road?
jad568
02-11-2015 12:08 PM
Audi42LV8
07-29-2009 11:17 AM
