Audi A6 3.2 2006 Speaker Replacement?
hi i have got a Audi A6 3.2 2006 model i want to change my factory speakers as they a damaged or faulty (in fact i have already replaced them with kenwood speakers but the sound very bad i think it is not matching them)
That being said, many people have good success changing factory speakers to a recommended version from Crutchfield or even changing out the factory head units. YMMV.
Try the C6 forum and check the technical resources/electronic tab.
Unless efficiency is an issue, or unless the speaker's impedance is calculated into the crossover, moving from 2 ohm to 4 ohm should not be a problem.
Either of the above caveats is very possible however.
Grant
Grant
As a general rule aftermarket speakers won't match impedance with OEM..lots of Audi speakers are 2ohm speakers, aftermarkets generally 4ohm.
jamiegull
Audi A3 / S3 / RS 3
01-17-2013 01:35 PM
pr0digy30
07-29-2005 10:18 AM
Leester
9
10-12-2004 05:56 AM
