Audi A6 4F - Electrical Rear Lid - Comfort module coding help !
Hello.
Does anyone in here have a station A6 4F with electrical trunk lid and a VAG COM ?
If so could you please post the coding for the comfort module 46 ?
I have today installed an electrical rear lid system in an Audi A6 4F but it does not work as intended.
I added the module 46D in the CAN Gateway list and I have fine contact with it via the diagnostics.
I can see in the coding helper of vag-com :
+1048576 = Luggage Compartment Closing Assistance (PR-4E7/4E9)
+2097152 = Rear Lid Control Module (PR-4E7/4E9)
Which of them is correct and what does each of them mean ?
I have tried to code the comfort module (46) with both of this settings , both at once , one at the time but same result : The power locking actuator will not react.
The actuators for moving the rear lid up and down it will work but the one that pulls it down the last step won't work at all.
The comfort module installed in the car was 4F0 910 289 F and I have replaced it with 4F0 907 289 K (software 4F0 910 289 K) that I understand it should work.
Whatever I do the locking mechanism will not activate ? (I can manually activate it so the actuator works).
Maybe someone with a power rear lid can post their coding of the comfort module ?
Any ideas or input appreciated.
Mr Spanner
03-19-2018 01:17 PM
Wissem1981
07-03-2017 06:29 AM
bigredbear
04-06-2007 02:20 PM
