Audi a6 c6 2009 keyless key fob not working
Have problem with my keyless key on 2009 c6 cdya. Master key worked well until i accidently put it in washing machine. Now if i changed battery key is not working, red light flashes only. If i open car manually then alarm goes on and i have to start car fast with that key then alarm goes off. Now if i use spare key i can open doors with it on key buttons but keyless function is not working. Is it possible to reprogram master key at home or should i go to dealer or may that key be damaged after being in water ? How can i activate keyless funcion on my spare key ?
Thanks
Thanks
The flashing means that the fob does not sense the car. Since you just replaced the battery, it failure to sense the car probably means that the fob is broken and needs to be replaced.
there is a guy in UK asked the same questions and he sorted out by.
"soaked the circuit board in contact cleaner a second time and left it open for a month."
RE: Recoding new key fob (keyless system)
-tishi
-tishi
