Last edit by: IB Advertising
- Audi A6 C6 Tires General Information and Specs<br>Important information to help you understand your Audi A6 C6.
Audi Wheel Bolt. How much torque?
#12
#14
I have heard of people putting some around the seat between the bolt at wheel, but NEVER on the threads. I personally would never do it. If you don't over tighten, you should not have any issues.
BTW, to correct my previous post above, it appears that some Audi with Alloy wheels also recommend 120 N-m of torque on the lug-bolts. Check the manual!
#15
I did this summer for the very 1st time.. I was hesitant after reading posts but what I did was i tested it on 1 lug.. Applied a small amount on seat n thread and tightened then immediately took it off to to see if it felt any easier to remove.. It didnt i also visually inspected the lug to see how much anti seize was on lug ...nothing significant .. So I decided to do them all and run them for a short while nbecause I knew I would have them all off soon after for a test fit of another wheel and I would test for looseness then. I had them off for the fitting 2 or 3 weeks later ...no issues they removed fine...Normal tightness... I took them off last month to run my stock wheels n did not reapply anti seize, just figured I did not need to... I'll decide on a reapplication in spring when I return to my summers.
#16
Audi allroad wheel nut torque
After searching online and getting ideas, but nothing 100%, I've managed to find the proper information from the Bentley Publications Audi A6 Service Manual, which covers the following models 1998, 1999, 2000, 2001, 2002, 2003, 2004 A6, S6 allroad quattro, RS6.
In section 4, chapter 44-1, under the heading 'Tightening torque' it states 'Wheel bolt to wheel hub' 120Nm (90 ft-lb).
So if any of you are wanting this info, this is accurate from the A6 Service manual. I hope this helps anyone needing the same information. Also if you are putting wheel spacers to these A6 model, it is advisable to use the same torque figures as the wheel nuts, but REMEMBER after driving 100 miles with new spacers on, RECHECK and re torque the bolts on both the spacers and the wheels.
#17
Yeah, the correct value is 88 ft*lbs on this car.
#20
Qurraci, it's still 88 ft*lbs for the majority of Audi cars. The SUVs use different values.
If you wish to double-check, it's always going to be found in your Owner's Manual.
