Background Lighting setting?
Has anyone else noticed or been annoyed that settings of the background lighting go away as soon as you turn off the car? Or has anyone figured out a way to make them be tied to headlight usage? I love the way the ambient lighting looks but it is really irritating to have to turn it on every time it's dark out.
Hey,
I don't have that issue. I set mine up initially and I've never had to do it again. You are refering to the lights in the footwells and in the doors?
Craig
Craig
Memory settings are programmed individually into each of your 2 FOB keys. I believe the other key (black plastic one) will reset everything back to factory defaults. Anyone else know?
Sometimes even though I'm using the same key, I find the radio sound settings have changed.
Audi's do have ghosts.
Same key and I never put the key in the ignition it's always in my pocket (I sooo love the advanced key).
I have NEVER had the light settings stick. How do yours work? Are they always on or do they just come on when the automagic headlights switch from Daytime Lights to regular Headlights?
I use Auto for the headlights and the ambient lighting comes on when it gets darker. Only had to set it once and it comes on every time.
However, I have noticed that my sound settings for CD will sometimes go back to default
and my passenger side wing mirror doesn't always go back to the original position
Since Audi can never repeat it they told me that they can't fix the problem !
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
I didn't get the Advance Key and I also don't use my auto lights. I prefer turning them on myself. My background lighting comes on when the headlights are turned on. Sometimes they are hard to see if you're in a well lit place. I don't save them, just set them and back out of the menu where the settings are.
Craig
Craig
My mirror works most of the time but to be honest I don't really need it to lower that frequently as it is so I'll probaby just turn off that feature and leave it set on the heat setting.
The ambient light thing is super easy to reproduce as it happens every time so maybe I'll have them look at it.
I think my cd player settings stick for the most part too.
