Bad blower motor?
I have a 2008 with 77,XXX miles and the blower has stopped working. For approximately two weeks the HVAC blower would take between 30 sec and 1 minute to start working after the car was turned on, but today it stopped altogether. There were no unusual sounds coming from the blower before it quit - at least anything I could hear inside the car.
1). Is there anything I should check to help diagnose the problem? Anything I can check with my VAG COM?
2). Does it sound like the blower motor might be the issue? I read other threads with similar issues but nothing that definitely said the problem was a blower motor.
3) Is the blower motor easy to replace and do I need a Bentley manual? I don't have one right now.
Any help would be appreciated, otherwise I'll just order a Bentley Manual and a new motor and see how far I can get.
- Mike
PS - I'm in St Louis and absolutely hate my dealer and would rather drive without air than give them another dime.
- Mike
Here are the VAG scan results. Now that it isn't working at all should I reset the codes and see what it pulls? The date on the code below is 7/13 which I suppose is the first time it had a problem?
Thanks,
-Mike
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000030297404
Coding: 0524326
Shop #: WSC 02125 758 00200
VCID: 1C3DF5C0DFB0E69
1 Fault Found:
01273 - Fresh Air Blower (V2)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 13
Reset counter: 121
Mileage: 123836 km
Time Indication: 0
Date: 2012.07.13
Time: 16:44:48
Freeze Frame:
Temperature: 45.0°C
Speed: 0.0 km/h
(no units): 25.0
(no units): 220.0
Thanks,
-Mike
Coding: 0524326
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 121
Mileage: 123836 km
Time Indication: 0
Date: 2012.07.13
Time: 16:44:48
Freeze Frame:
Temperature: 45.0°C
Speed: 0.0 km/h
(no units): 25.0
(no units): 220.0
I replaced the blower motor/fan today and everything seems to be working fine. Because I wasn't sure if that was the problem, I purchased a used part off ebay for $80 shipped. A new fan was twice that.
It took about two hours but would take less than half that the next time around. The only tool I needed was a long handled T-15 torx wrench which is used to remove all the screws.
I took several pictures during the process and may post them later but for those who are wondering what access to the fan looks like, here is a pic.
![](http://i2.photobucket.com/albums/y10/mpcart/PhotoSep0393059AM.jpg)
The only difficult part was removing the wiper blades and accessing one screw in the back that was tucked under some sheet metal. Very easy DIY project.
-Mike
-Mike
-Mike
-Mike
Hey, thank you for the post.
I have 3 A6 C6 cars.
On my 2008, I have been getting a delay in blower motor coming on. One freezing winter night, I had no defrost or heater at all. Half way in my journey (about 20 mins) it came on. Sometimes it would delay blower motor running, I put it off, for the most part, it worked. Today was 90+ F out, and blower motor would come on late, or not at all. I'm thinking maybe just order a "resistor", which I understand to be a speed controlling module. Any thoughts? Yesterday, AC came on 5 mins into drive, and was cold. So I assume charge is good.
Maybe a dirty relay somewhere? Can anyone post a wiring schematic for blower motor and module?
Thanks!
Thanks!
Don't want to start new thread for exact same problem, but I do also have DTC:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 293815 km
Time Indication: 0
Date: 2023.11.02
Time: 07:22:02
Freeze Frame:
Temperature: 21.0°C
Speed: 31.0 km/h
(no units): 16.0
(no units): 221.0
I must say that I have never noticed that the blower is not working (can't say for sure since it's on auto and, depending on temperature, most of the time it's on very low speed/sound) and since I don't think that a simple EM motor can easily fail (except if it's burned off completely), I was wondering has anyone had any experience on this matter in domain of worn brushes creating open circuit?
Before I dig into this (hopefully not blindly), it would be appreciated if someone can clarify a few thing for me:
-Does the wiring around the blower tends to go bad/crack or maybe control module on blower tends to fail?
-Does anyone knows can this specific blower be disassembled for repair service (replacing brushes, cleaning rotor shaft, etc)?
-Does it have CP?
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 293815 km
Time Indication: 0
Date: 2023.11.02
Time: 07:22:02
Freeze Frame:
Temperature: 21.0°C
Speed: 31.0 km/h
(no units): 16.0
(no units): 221.0
-Does it have CP?
michael0156
01-31-2004 04:40 PM
