Battery died, now MMI does not turn on
2005 4.2 S-Line
My car has been sitting at the shop for about a month, give or take.. The battery was dead when I tried starting it, so we charged up the battery, car started fine but the MMI screen will not turn on. We ended up putting a brand new battery in and still the same issue. Everything was a 100% working before we took the oil cooler off to change 2 O-rings. The threads that I've read point to an optical/control head issue... but again everything was working fine before the battery died. Anyone ever encounter this? Or know of a remedy?
2005 4.2 S-Line
Most likely when you jump started the car you blew a fuse which caused the MMI to become inoperable. Check the passenger side fuse panel right on the side panel and you'll see a fuse related to radio/MMI function. That's where I would start and also run a VCDS to see if there aren't any other things going on.
You don't think modified headlights would have anything to do with this, right?
After extensive searching, I realized that you had a similar problem a while back:
https://www.audiworld.com/forums/a6-...2873702/page2/
My aim later today will be checking all fuses again and going from there.
audigwirl (09-28-2023)
Ok. How do I code the battery? I know how to do it through VDCS but the brand of the battery is AutoStart. I don't see it as an option in the list. Anyone know how I go about this?
https://www.audiworld.com/forums/a6-...cment-2879428/
Battery Replacement - Ross-Tech Wiki
By modified headlights, I removed the AFS unit internal/external from the right stock headlight, the left headlight was replaced recently by previous owner with no AFS, and I also added a DRL LED strip to both headlights
Good news. I fixed the issue. The shop checked the fuses with a tester, I did the same after I got home, then after it rained I decided to check them all one bu one y pulling them out. Sure enough, it was the same exact fuse as in your previous thread that I posted. Communication Fuse.
